Hey all,
Just need some options / ideas.
Im going to sell the GTR in the not to distant future, as its only my daily and id like something a bit more modern, new and able to fit 4/5 fairly comfy.
Looking for something modern
$22, 000 or less ish
Nothing older then around 2000
Prefer big enough for 4 people
Manual preferably
Sporty looking but very comfortable as a daily
Something not totally gutless
Something I can make look decent, rims lowered exhaust etc
Leaning towards a nissan V35.......
but any other ideas??
Cheers
Adam
https://www.sau.com.au/forums/topic/429815-car-options-ideas/
How about something like this? It doesn't meet all your criteria but it certainly matches most of them http://www.carsales.com.au/private/details/Mercedes-Benz-C32-2003/SSE-AD-2136168/?Cr=99&sdmvc=1
Bro-in-law owns a TRD Aurion. Nice car, plenty of grunt, lots of room for four adults, decent looking without being over the top and nice interior. Interior plastics are typical Toyota but they did a reasonble job of adding some flair with colour.
An Evo :yes:
Haha thanks mate, already had an evo :P
Just not sure about auto only and front wheel drive, but definatly on my list to atleast have a look at
Theres a 1JZ powered Lexus IS on JDMST.. Maybe worth a look if your after a faster version...
any link mate i cant see it??
can't go past a stagea, can go camping, heaps of room and power etc
Not really my thing, never been a huge fan
  • 2 months later...
Interesting
Ive narrowed it down, so far. well at least want to have a look at the following
-V35
- IS200
- 350z
- GS300
- TRD aurion
Mums and Dad both drive Gs300's my sister got an is200 if I had to pick between them is say the GS purely because it is a better ride then the is but a trd aurion are quite good to my cousin has one there not as quick as a standard r34gtt but for what they are there really good
The 350z = a modern Stagea, what is it you are against exactly? Wagons?
Aurion = front wheel drive = Ghey. Adding a supercharger doesn't change anything... Just my opinion.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
