Hey people, I bought a skyline with a lot of mods but have yet to get it dyno'd so i have no idea what kw's its putting out.
I've listed what its had done and hopefully some1 can tell me possibly what power it could be putting out and any estimated times likes 0-100 km/h, quarter mile. I know nothings rock solid till I get papers to prove. Im after a sheer estimate.
The car is:
r33 GTS25T 95' Series I
GTR Front Mount Intercooler
GTR Fuel Pump
T3/T4 Highflowed VL Turbo
Apexi S-AFCII *yet to be tuned at Croyden 'Racing Emotion' will get Dyno before and after*
GReddy Profec B Boost Controller
Blitz Dual Turbo Timer
3" Exhaust
High Flow Cat
MegaFlow Muffler Twin 2" Tip
Pod Filter
Blitz Open-Atmosphere BOV
Brass Button Clutch
Locked Dif
Light Racing Rims
9.5" Wide Rear Tires
Lowerd 3" Inch *Estimated*
Strut Brace
Always run Optimax 98 Octane.
Stock ECU *Yes, PowerFC soon, Autronic would be nicer*
Max Boost 10psi because of Stocko ECU.
I'll have to get it on strips soon. Have to get 3-point belt first right?
Anyway anyone who has similar mods and any times, or readings would be great.
Cheers:run:
https://www.sau.com.au/forums/topic/42982-guess-my-rwkw-from-these-mods/
  • Replies 81
JimX, can you please explain why you dont agree that the Autronic is not nicer then the PowerFc
uh, oh ... i can see another ECU debate brewing ;)
Depending how the SAFCII goes with the static ignition timing i think you will make about 220rwkws with more to come with the management sorted...provided your T3/4 is a good thing
I didn't say the Autronic wasn't a better ECU. I was looking at his mods which are very mild, and wondering why he thinks an ECU geared up for racing cars would be "nicer". I'm not sure, but doesn't it ditch your climate control along with many other aftermarket ECUs such as Motec? This could have been something they've fixed, but I seem to remember way in the past reading that it didn't support the Skyline's climate control.
For a mild car, all I can see in an Autronic would be a higher initial purchase cost, higher tuning costs, a limited number of tuners that could do it, and potentially no more climate control. "Better" argument aside, I still can't see how it is "nicer".
Ahhhh great estimates, thanks.
I have done 0-100 in 6.01 with 1 passenger at 10psi, granny shifting with a stop watch.
I was a little disappointed with that thinking i would get into the 5's possibly a little easier. I would have to get into Mid 5's if i was running 10psi, No passengers, and Double Clutching. You can really feel the difference even with one passenger.
As for Quarter Mile. I did a street quarter mile at an approx 13 sec with 1 passenger, 10psi, granny shifting. I believe i'd get into mid to low 12's if no passengers, double clutch.
One Last Question. If I got my new ECU and say boosted to 14 - 16 psi. What type of rwkw and Quartermile times could i get then. Would we be talking about low 12's, high 11's would be nice. The difference between 7 and 10 psi is huge. That extra 3 psi gives me 20km/h higher speed in 2nd gear. So if i had another 4 - 6 pound. I'd imagine it'd really start flying then.
Cheers:run:
Yeh good point, I wouldnt get a Autronic for 2 reasons in my situation. 1. The price. 2. I'd have no use for my T Timer or Boost controller no more. Autronic handles all that. Its funn adding parts here and there to your car. There's a place i seen who said they'd do an Autronic for me for like $3000 or something, they great mechanics, but I'd just go the PowerFC coz all up you can buy 1, have it installed and tuned for around $1600. I never knew that about Climate Control? Surely the new models wouldnt have that problem, anyway who cares, i aint getting one.
Thats odd, as the top speed in each gear is restricted by the rev limit, unless you were shifting earlier, and changing boost wont change your rev limited
You should go a lot faster if you dont double clutch, you only need to double clutch a non-syncro gearbox, like an old truck or something.. meaning push the clutch in, let it out when its in neatural and blip the throttle, push the clutch back in and finish the gear change...
Guest INASNT
hahaha u think u would run quicker 0-100 times if u were double clutching?????
I think u mean flat shifting????
double clutching? wtf? i think you've been watching a little too much fast and the furiNAWS.
vin diesel's granny shifting speech was full of crap and didn't make sense... oooh..
Hmmm Ok. Firstly Yeh. I usually run standard 7 psi. Which gives me 80km/h in 2nd at around 6500 rpm. when i use boost controller and put it up to 10psi, i can do 100km/h in 2nd gear at same rpm 6500
As for doubleclutching. Have you even tried it? It really kicks you in to the back of your seat surges the car forward. The difference between 'flat' shifting and double clutchin in 3rd and above makes quite a difference. Certainly gets you do the next gear quicker.
:run:
Cheers:run:
This thread is great!
Must be all that "double clutching" which is changing your gear ratios on the fly dude!
Correct if im wrong...double clutching is depressing clutch entering neutral releasing clutch...get the sybnchros moving then depress clutch and enter gear...gas on..?
Thats not what u do in a drag...u just quick shift or flat shift
Guest INASNT
:run:
Yes Vin Diesel what you were told to say in the script is WRONG.
Please explain to us what you think double clutching is????
:run:
Dude the car does Nkm/h at Xrpm regardless. You will not change this without changing the gear ratios in the gearbox or the diff.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
