Hey people, I bought a skyline with a lot of mods but have yet to get it dyno'd so i have no idea what kw's its putting out.
I've listed what its had done and hopefully some1 can tell me possibly what power it could be putting out and any estimated times likes 0-100 km/h, quarter mile. I know nothings rock solid till I get papers to prove. Im after a sheer estimate.
The car is:
r33 GTS25T 95' Series I
GTR Front Mount Intercooler
GTR Fuel Pump
T3/T4 Highflowed VL Turbo
Apexi S-AFCII *yet to be tuned at Croyden 'Racing Emotion' will get Dyno before and after*
GReddy Profec B Boost Controller
Blitz Dual Turbo Timer
3" Exhaust
High Flow Cat
MegaFlow Muffler Twin 2" Tip
Pod Filter
Blitz Open-Atmosphere BOV
Brass Button Clutch
Locked Dif
Light Racing Rims
9.5" Wide Rear Tires
Lowerd 3" Inch *Estimated*
Strut Brace
Always run Optimax 98 Octane.
Stock ECU *Yes, PowerFC soon, Autronic would be nicer*
Max Boost 10psi because of Stocko ECU.
I'll have to get it on strips soon. Have to get 3-point belt first right?
Anyway anyone who has similar mods and any times, or readings would be great.
Cheers:run:
https://www.sau.com.au/forums/topic/42982-guess-my-rwkw-from-these-mods/
  • Replies 81
JimX, can you please explain why you dont agree that the Autronic is not nicer then the PowerFc
uh, oh ... i can see another ECU debate brewing ;)
Depending how the SAFCII goes with the static ignition timing i think you will make about 220rwkws with more to come with the management sorted...provided your T3/4 is a good thing
I didn't say the Autronic wasn't a better ECU. I was looking at his mods which are very mild, and wondering why he thinks an ECU geared up for racing cars would be "nicer". I'm not sure, but doesn't it ditch your climate control along with many other aftermarket ECUs such as Motec? This could have been something they've fixed, but I seem to remember way in the past reading that it didn't support the Skyline's climate control.
For a mild car, all I can see in an Autronic would be a higher initial purchase cost, higher tuning costs, a limited number of tuners that could do it, and potentially no more climate control. "Better" argument aside, I still can't see how it is "nicer".
Ahhhh great estimates, thanks.
I have done 0-100 in 6.01 with 1 passenger at 10psi, granny shifting with a stop watch.
I was a little disappointed with that thinking i would get into the 5's possibly a little easier. I would have to get into Mid 5's if i was running 10psi, No passengers, and Double Clutching. You can really feel the difference even with one passenger.
As for Quarter Mile. I did a street quarter mile at an approx 13 sec with 1 passenger, 10psi, granny shifting. I believe i'd get into mid to low 12's if no passengers, double clutch.
One Last Question. If I got my new ECU and say boosted to 14 - 16 psi. What type of rwkw and Quartermile times could i get then. Would we be talking about low 12's, high 11's would be nice. The difference between 7 and 10 psi is huge. That extra 3 psi gives me 20km/h higher speed in 2nd gear. So if i had another 4 - 6 pound. I'd imagine it'd really start flying then.
Cheers:run:
Yeh good point, I wouldnt get a Autronic for 2 reasons in my situation. 1. The price. 2. I'd have no use for my T Timer or Boost controller no more. Autronic handles all that. Its funn adding parts here and there to your car. There's a place i seen who said they'd do an Autronic for me for like $3000 or something, they great mechanics, but I'd just go the PowerFC coz all up you can buy 1, have it installed and tuned for around $1600. I never knew that about Climate Control? Surely the new models wouldnt have that problem, anyway who cares, i aint getting one.
Thats odd, as the top speed in each gear is restricted by the rev limit, unless you were shifting earlier, and changing boost wont change your rev limited
You should go a lot faster if you dont double clutch, you only need to double clutch a non-syncro gearbox, like an old truck or something.. meaning push the clutch in, let it out when its in neatural and blip the throttle, push the clutch back in and finish the gear change...
Guest INASNT
hahaha u think u would run quicker 0-100 times if u were double clutching?????
I think u mean flat shifting????
double clutching? wtf? i think you've been watching a little too much fast and the furiNAWS.
vin diesel's granny shifting speech was full of crap and didn't make sense... oooh..
Hmmm Ok. Firstly Yeh. I usually run standard 7 psi. Which gives me 80km/h in 2nd at around 6500 rpm. when i use boost controller and put it up to 10psi, i can do 100km/h in 2nd gear at same rpm 6500
As for doubleclutching. Have you even tried it? It really kicks you in to the back of your seat surges the car forward. The difference between 'flat' shifting and double clutchin in 3rd and above makes quite a difference. Certainly gets you do the next gear quicker.
:run:
Cheers:run:
This thread is great!
Must be all that "double clutching" which is changing your gear ratios on the fly dude!
Correct if im wrong...double clutching is depressing clutch entering neutral releasing clutch...get the sybnchros moving then depress clutch and enter gear...gas on..?
Thats not what u do in a drag...u just quick shift or flat shift
Guest INASNT
:run:
Yes Vin Diesel what you were told to say in the script is WRONG.
Please explain to us what you think double clutching is????
:run:
Dude the car does Nkm/h at Xrpm regardless. You will not change this without changing the gear ratios in the gearbox or the diff.
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
