  • Replies 81
Pretty much after you changed into your next gear release the clutch, then quickly push it back in again and straight back out whilst Still keeping your foot on the throttle.
I've just re-read over the posts again. The above is from Jamesh.
What you are doing is what I call dipping the clutch.
I usually do it after a launch that has gone wrong and caused the car to bog down.
I will be happy to test your double clutching against my flat shifting. ;)
I get more *power* from flat shifting, I know this because If I flat shift hard in to second it will cause second to spin until third.
I don't know how laggy your turbo is, when I select the next gear boost is instantly on the full 16psi. There is no lag between gears. UNLESS I shift too early causing my next gear rev's to drop below 4000rpm.
I see what you are doing and there is no doubt it will kick you in the back as you are popping the clutch with the rev's near redline.
Do a few launches with really hard changes then do the hard changes + your clutch dip after its already in gear. You will get a slower 0-100time with your clutch dipping.
Also... You say you run 0-100 in around 6secs?!?!
Are you launching bad or have you been ripped off and sold a car with a std. turbo?
My car boosted I run 0-100 anywhere from a low 5sec to mid 5sec (best being a fairly consistent 5.2secs).
If wheelspin breaks out then 0-100 will be around the 6-7 sec mark.
I've got launching down pat, 4200rpm nice smooth easing of the clutch out slight bit of wheel spin through out first (7200rpm change) with the wheels only just chirping hard change in to second and take rev's to again around 7400rpm. By then I'm doing 100km/h.
If I change earlier obviously My 0-100time increases slightly as it is time wasted changing gears and off power :D Kind of cheating but its not a 1/4 time its a 0-100 time. :D
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
