G'day Neil - how have you been ??
Not sure if you'll be interested, but Unique have a diff upgrade fro around $1200 I think. Makes it tighter etc... Or you may be able to find a 1 or 1.5 way for around $500 which may be less you'd pay for a stock rebuild..
Not sure how much it'd cost to fix up the stocker.
J
https://www.sau.com.au/forums/topic/42984-diff-rebuild/#findComment-877299
Neil - I think there is a place in Wahrongah (near Hornsby) that can rebuild them - Called Wahrongah clutch & diffs or something like that -
Forget the 1 way - go the 1.5 or 2 way - UAS has Tomei ones on their web site -
Pretty pricey but.
Maybe powerplay have got a good deal going ?
https://www.sau.com.au/forums/topic/42984-diff-rebuild/#findComment-877340
only thing with the mechanical diffs (as Jody will confirm) is they are pretty grumpy and noisy.
If thats not a problem they are *definately* the way to go
If not you can apparently get extra shims added to the standard LSD style diff to get it to hold tighter as well. By all accounts the stock locking pressure is pretty mild even when it is working OK.
https://www.sau.com.au/forums/topic/42984-diff-rebuild/#findComment-877439
Yes I have a 1 way... VERY clunky... but you can learn to drive them quietly I have been told... I'm getting better, but means another thing to think about... and they SUCK in car parks!
BUT...
They Kick ARSE on the track totally!
https://www.sau.com.au/forums/topic/42984-diff-rebuild/#findComment-877979
Thanks for the reply.
I want to keep to standard as possible, I hear all the time people say when they buy other diff's they get noisy and clunk a fair bit..
Just throught getting the old one recod. would be safe..
regards
https://www.sau.com.au/forums/topic/42984-diff-rebuild/#findComment-878191
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
