Hi,
I am just about to install ID1000 injectors in my RB26DETT.
I read on the homepage of the manufacturer that all ID injectors are high impedance.
However the standard RB26 injectors are low impedance and the GT-R has a resistor ballast installed as the stock ECU is working natively with a high impendance signal. Do I therefore need to bypass this resistor ballast? I am using a Power FC ecu...
Thanks!
All of them.
Thats obvious, but which Pins exactly have to be connected to each other?
Edit: Just checked the circuit plan and now it makes all sense. All seven wires have to be connected with each other, I better get a strong soldering iron then. :)
Edited by Behind Horizon
  • 1 month later...
google is your friend...
make SURE you soldier it up, i was lazy and thought i would get to it later, but i did not end up doing it then one of the injectors would lose connection every now and then causing one cyl to turn off sometimes.....
https://www.google.ae/search?q=rb26+resister+pack&oq=rb26+resister+pack&aqs=chrome..69i57j69i60j0l3.4275j0&sourceid=chrome&ie=UTF-8
just cut the wires and bunch them ALL up and pour a crapload of soldier over it and tape it up and remove the resister pack from the engine bay as its not needed anymore.
  • Like 1
Ok I'm going to do this soon with new ID2000's
I see the resistor ballast thing has a harness connector, can you just disconnect it and remove the resistor all together and it will work ?
If not which wires do I need to cut and join? I'm guessing the ones that stay in the car then once that's done remove the resistor ballast?
Anyone got pics of what to cut and join?
Thanks
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
