Shed Clear Out! New Parts, Gates T-Belt, Alpine Speakers, Neo Parts, Consult Cable, 26 P/s Pump + Bracket, Turbo Line Kit, Header Tank, Turbo Oiler
Hello all. Shed clear out time!
Postage: Yes, at YOUR cost
Pricing: As listed, negotiable to an extent. No lowballers though
Items: As listed and described, all in good working order. All items are simply no longer required.
Contact: Via PM, All PMs will be responded to as swiftly as possible
Possibly more items to be added as i go.
R33 / R34 RB26 Power steering pump in good working order. $300
RB25 (will suit an RB) brand new Nissan fan - $130
RB20/25 or 26 with a single turbo brand new braided turbo line kit. Sonic brand - $160 ($220 new)
Gates performance timing belt - $70
Tomei RB20/25/26 Adjustable Inlet Timing gear - $130
Greddy Breather Tank, Complete kit, new. Unfortunately have to make a custom one for my vehicle - $150
Alpine Type R 6" 100Wrms 2-way speakers. One pair used but in great condition, the other pair brand new. Excellent speakers! $320 for all four! ($229 a pair retail)
Canton Turbo Oiler - This little baby will discharge approximately 1 litre of oil into the turbo after the engine has been switched off. It has the same concept as a turbo timer but the engine does not have to keep running. Comes with some fittings and hoses as shown, NO brackets supplied but these are cheap. Unfortunately there is just no room in my engine bay for it! - $180
RB25 NEO Brand new Nissan harmonic balancer. Crucial part for that 100,000km service that no one ever changes - $260 - CHEAP!
50W 6000k High/Low H4 HID kit with BA15S white parker bulbs. Hardly any use at all - $80
RB Exhaust manifold with heat shield in great condition - $50
RB25 NEO Plenum, sand blasted nice and clean - $60
RB25 NEO AAC Valve block assembly - Very clean - $50
RB25 NEO Purge control valve with bracket - These little shits have a tendency to break - $60
RB25 NEO Boost sensor and bracket - $80
RB25 NEO Factory Injectors - $80
S2 RB25 Throttle body, required when deleting the traction control throttle body on a NEO engine - $40
S2 / NEO Pink Label AFM, very good condition and working well - $70
RB25 NEO Boost control solenoid with plug and some wire - $50
RB25 NEO Stainless recirculation valve piping - $40
RB25 NEO Intake pipe - $35
RB25 NEO Cross over pipe - $40
RB25 NEO Rocker cover oil cap seal - $15
RB25 NEO Front coolant bleeder valve - $15
R34 Engine brackets, as shown, only the RH rubber mount is included - $35
RB25 NEO Turbo heat shield and O2 sensor - $40
RB25 NEO Timing cover, painted gloss black, it is just a bit dirty as the photo shows - $30
R34 Heater pipes - $25
RB25 NEO Oil heat exchanger block with oil pressure sender and oil temp sensor - $70
RB25 NEO Coil pack cover - $35
Nissan Consult Cable and vehicle consult plug + Nistune Single License - $260 (Must first confirm on the License)
R31 Factory cut open air box with performance washable panel filter. Includes intake as shown - $60
RB -10 Knock in type cam cover breather fittings - $40 including postage
Available soon: RB25 NEO Rocker covers that will come completely sand blasted ready for your favourite colour of paint. Covers have been modified so that the baffling plates are now screwed in and not riveted in. This gives you to opportunity to insert some better baffling material - $60
Photos To Come
RB20 Timing cover - $15
R31 Radiator overflow bottle, Suits HR and ADM, almost new - $50
R31 Wiper washer bottle with motor, Suits HR and ADM - Has Level Switch, almost new - $50
R32 RB20 Harmonic Balancer, no chips, rubber appears ok - $30
R31 RB30 Harmonic Balancer - $25
R31 Grilles - $25 ea
RB25 NEO Boost Sensor SOLD
R31 Radiator overflow bottle SOLD
RB25 Engine Fan Sold Pending Payment
RB Braided Turbo Hose Kit Sold Pending Payment
R33 / 34 GTR Power Steering Pump Sold Pending Payment
RB25 Cam Covers Sold Pending me finishing them and payment haha
R33 / 34 GTR Power Steering pump SOLD
RB25 Engine Fan and RB braided turbo hose kit BACK UP FOR SALE
NEO TPS in good working order - $70
New R32 RB20/25 Nismo Engine Mounts, Will also suit RBxx in an R31, may suit other models as well? - $150
Nismo Engine Mounts SOLD
RB25 Fan SOLD
RB25 NEO Injectors SOLD
RB25 Cross Over Pipe SOLD
RB25 NEO Plastic Timing Cover SOLD
S2 RB25 Throttle Body SOLD
RB -10AN Breather Fittings SOLD
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
