Shed Clear Out! New Parts, Gates T-Belt, Alpine Speakers, Neo Parts, Consult Cable, 26 P/s Pump + Bracket, Turbo Line Kit, Header Tank, Turbo Oiler
Hello all. Shed clear out time!
Postage: Yes, at YOUR cost
Pricing: As listed, negotiable to an extent. No lowballers though
Items: As listed and described, all in good working order. All items are simply no longer required.
Contact: Via PM, All PMs will be responded to as swiftly as possible
Possibly more items to be added as i go.
R33 / R34 RB26 Power steering pump in good working order. $300
RB25 (will suit an RB) brand new Nissan fan - $130
RB20/25 or 26 with a single turbo brand new braided turbo line kit. Sonic brand - $160 ($220 new)
Gates performance timing belt - $70
Tomei RB20/25/26 Adjustable Inlet Timing gear - $130
Greddy Breather Tank, Complete kit, new. Unfortunately have to make a custom one for my vehicle - $150
Alpine Type R 6" 100Wrms 2-way speakers. One pair used but in great condition, the other pair brand new. Excellent speakers! $320 for all four! ($229 a pair retail)
Canton Turbo Oiler - This little baby will discharge approximately 1 litre of oil into the turbo after the engine has been switched off. It has the same concept as a turbo timer but the engine does not have to keep running. Comes with some fittings and hoses as shown, NO brackets supplied but these are cheap. Unfortunately there is just no room in my engine bay for it! - $180
RB25 NEO Brand new Nissan harmonic balancer. Crucial part for that 100,000km service that no one ever changes - $260 - CHEAP!
50W 6000k High/Low H4 HID kit with BA15S white parker bulbs. Hardly any use at all - $80
RB Exhaust manifold with heat shield in great condition - $50
RB25 NEO Plenum, sand blasted nice and clean - $60
RB25 NEO AAC Valve block assembly - Very clean - $50
RB25 NEO Purge control valve with bracket - These little shits have a tendency to break - $60
RB25 NEO Boost sensor and bracket - $80
RB25 NEO Factory Injectors - $80
S2 RB25 Throttle body, required when deleting the traction control throttle body on a NEO engine - $40
S2 / NEO Pink Label AFM, very good condition and working well - $70
RB25 NEO Boost control solenoid with plug and some wire - $50
RB25 NEO Stainless recirculation valve piping - $40
RB25 NEO Intake pipe - $35
RB25 NEO Cross over pipe - $40
RB25 NEO Rocker cover oil cap seal - $15
RB25 NEO Front coolant bleeder valve - $15
R34 Engine brackets, as shown, only the RH rubber mount is included - $35
RB25 NEO Turbo heat shield and O2 sensor - $40
RB25 NEO Timing cover, painted gloss black, it is just a bit dirty as the photo shows - $30
R34 Heater pipes - $25
RB25 NEO Oil heat exchanger block with oil pressure sender and oil temp sensor - $70
RB25 NEO Coil pack cover - $35
Nissan Consult Cable and vehicle consult plug + Nistune Single License - $260 (Must first confirm on the License)
R31 Factory cut open air box with performance washable panel filter. Includes intake as shown - $60
RB -10 Knock in type cam cover breather fittings - $40 including postage
Available soon: RB25 NEO Rocker covers that will come completely sand blasted ready for your favourite colour of paint. Covers have been modified so that the baffling plates are now screwed in and not riveted in. This gives you to opportunity to insert some better baffling material - $60
Photos To Come
RB20 Timing cover - $15
R31 Radiator overflow bottle, Suits HR and ADM, almost new - $50
R31 Wiper washer bottle with motor, Suits HR and ADM - Has Level Switch, almost new - $50
R32 RB20 Harmonic Balancer, no chips, rubber appears ok - $30
R31 RB30 Harmonic Balancer - $25
R31 Grilles - $25 ea
RB25 NEO Boost Sensor SOLD
R31 Radiator overflow bottle SOLD
RB25 Engine Fan Sold Pending Payment
RB Braided Turbo Hose Kit Sold Pending Payment
R33 / 34 GTR Power Steering Pump Sold Pending Payment
RB25 Cam Covers Sold Pending me finishing them and payment haha
R33 / 34 GTR Power Steering pump SOLD
RB25 Engine Fan and RB braided turbo hose kit BACK UP FOR SALE
NEO TPS in good working order - $70
New R32 RB20/25 Nismo Engine Mounts, Will also suit RBxx in an R31, may suit other models as well? - $150
Nismo Engine Mounts SOLD
RB25 Fan SOLD
RB25 NEO Injectors SOLD
RB25 Cross Over Pipe SOLD
RB25 NEO Plastic Timing Cover SOLD
S2 RB25 Throttle Body SOLD
RB -10AN Breather Fittings SOLD
    • Sell it and buy something newer? 馃槢
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
