Hey guys just put in my bc br coilovers in my r33 and initially they were very bouncy. Springs are 6kg/mm F and 4kg/mm rear.
The dampening settings were 8clicks off full hard front and rear. Ive backed it off a bit 16F and 24R and it feels better.
Also they seemed to be running a heap of preload like 8mm. I made the springs just captive and that improved it still but ride is still bouncy.
Anyone know the recommended preload and or dampening seting i should be using for custom spring rates.
Cheers
Patrick
Pre-load shouldn't affect ride noticeably. Personally I wouldn't be confident that the damping settings on BC's are repeatable between sets - without some evidence.
Normally the term "bouncy" is used when the rebound is set too low and the car oscillates up and down after a bump. I think you must mean "harsh" or "stiff" if backing off the damping helped (the compression damping was too high).
I don't hold much hope that anyone will be able to help you over the internet. So maybe just play around and see what you like. Otherwise take them to a proper suspension place and get them set. But by then you'd be better off having sold them and bought Shockworks or MCA Blue.
The BC BR's aren't a bad set up for the dollars.
Why not start with them fully soft and work your way back from there?
You say they're too bouncy, yet you're running the rears 6 clicks out from full hard. :whistling:
You want to be running the damping as soft as you possibly can and still suit your driving style/roads.
set preload at 0 and the dampening to full soft front and back then adjust depending how it feels. If the car feels to soft increase front and rear a few clicks , if its understeering add a few clicks in rear and for oversteer add a few in front until you reach a good balance.
  • 4 weeks later...
What do you think of these coilovers? I'm looking at getting some for my r33 gt
Are you poor or can you afford decent suspension?
HAHAHAHA Wiggles, if you can afford a GTR you should hopefully be able to buy decent stuff. Go for Bilstein PSS9 (or just damper+spring combo) or else something better...like Ohlin's
Eh just saw that they were there and cheaper seemed good enough. Will probably go for apexi n1 or similar
Got a link for the öhlins?
Edited by Wiggles
Nonononono. Don't just buy coilovers, especially Jap coilovers, without thinking about what they are made up out of. A set of B6 Bilstein dampers and Whiteline springs would be a better option than almost any set of coilovers if you're talking about a road car. You have to spend a lot on coilovers to get actual good quality stuff.
Which is why I mentioned for a road car. Track cars can and do need a lot of spring rate. But a lot of spring rate on a road car just makes for a bouncy bucket of shit. Australian roads, even the main roads in the suburbs, are just too rough. You can actually drive faster and get better handling if the tyres stay in contact with the road. </preaching to the converted>
I have nismo s tune on my car now, the reason I wanna change them in they lack adjustability. With the apexi they have a similar spring rate + the adjustability that the nismo lack.
My car is predominately a streeter but if I get the chance I take it on a track, I mean that's why we buy these cars right. To enjoy them?
Also I've been in a car with cusco 12/10 spring rates ant it was in no way comfy. My previous had tien super streets.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
