bumpity bump - do you still come on here Markos?
I started doing BB tricep extensions this week in addition to everything else, still finding it hard to get the reps out, especially in the squat and overhead press. I think my squat form is still lacking slightly - I'm trying to keep my head down as is shown in Starting Strength, but it really does not feel right? Lower back is the weak point where I can't physically get any more reps out in a set, currently I'm doing 12,12,12,8 @ 125kg.
It's possible that I may be trying to jump too much in weight, as the gym only has 1 set of 1.25kg plates, so usually I have to use 5kg increments.
I'm gradually grinding out an extra rep or 2 on each set every time, but the progress is slow, is this the right thing to do, or is there something else I should be doing? I went up to 135kg 3x10 for a week, which was fine, but did not seem to make any difference either way?
I'm still doing the Tabata cardio on the two non lifting days during the week for 3x4 minute intervals doing thrusters with only 2kg dumbbells.
Edited by bozodos
I purchased my own 1.25 as they only have 2.5 at my current gym, they cost about $10 a pair, I painted mine "Vixen Red" and they live in my gym bag.
Doesn't the squats say 2x15 or 3x10.... Which are you doing to = 12,12,12,8?
I was under the impression that it would look something like (for 3x10) Yx10, Yx10, Yx8, more is say Yx6....
Next time Yx10, Yx10, Yx10...then up weight....
Yx10, Yx9, Yx8, more Yx5..
Yx10,Yx10,Yx10.....Up weight Etc...
The head isn't meant to face down, just so the back is straight. Shoulders should be so tight that head nearly sits in correct spot without thinking.
Also, if you're doing a 5x5 deadlift day as well, you aren't doing his beginners program anymore, as it strays from it? Not that it probably matters, unless it's what's slowing progression.
Definitely get yourself some 1.25kg plates.
If you're grinding out an extra rep 3xweek then going up 2.5kg a week, in 52weeks that's a lot of change.
it's meant to be 2x20, which was fine up until 125kg lol. Trying to progressively do more reps spread over less sets. There is 2 versions of the beginner program, which is why I'm asking for Markos' take on it.
Yes the 5x5 deadlift day diverges a bit from the routine - I have 2 non lifting days following it though, and have no issues with deadlift progression. That said, I might be doing too much volume for deadlifts as it is. To be honest the 3x15 straight backed SDL that I do are harder than doing singles, doubles or sets of 5 of regular deadlift. They have helped a lot with it though.
Good idea on getting my own 1.25kg plates btw.
I know that my squat form is still probably not 100%, I'm in the process of looking into getting some actual coaching, as the gym does not offer any.
Overhead press - do you know what you are doing/ how to do them correctly? Are you doing the 'bro' version behind the head? Or the proper version?
Squat wise - Keeping your head down? You might be over thinking it. It's probably in there for you to help learn hip use. Lower back shouldn't be the weak point (unless its injured), this isn't deadlift.
yeah doing the proper version Rev, feet shoulder width apart, clean barbell, then press it, trying to make sure that arms are in and yes in front of the head too.
20 reps is what the program states - I can do more weight, lower reps no problems at all. Like I said, I'm not discounting my form - I have been making sure to keep shoulder blades retracted and the bar nice and low - this has stopped me from wanting to roll forward, and I've been keeping a neutral head position vs looking up or down as it feels more natural.
  • 3 weeks later...
just as an update to this thread, I started doing the second version of the PTC beginner program (3x10 squat / SLDL, 3x8 everything else) about a week ago, all lifts have been improving steadily (dips and curls the slowest). I possibly jumped up in weight too much too quickly to start with, dunno.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
    • Yeah, all good ...got your postal addy as well ; I'll box the stuff in the next couple of weeks, you can paypal me later..
    • Hello! I had a mid life crisis on a budget and coincided with the R34s being legal in the USA. And now I am here, with it having old car problems and me slowly hoarding parts to start building it to what I envision. Essentially I made a mistake, that lead me to join this forum filled with legends.
