AFM will be good for over 350rwkw.
Injectors - depends on pressure. If you up the base to say 45psi then you'll squeeze more out of them easily enough... Also depends it seems on the tuner, E85 and fuel use seems to vary pretty heavily.
Too easy thanks boys, atleast I don't have to worry about that now as I'm aiming for 350ish anything more is a bonus.
Can anyone recommend a tuner that won't insist ill need 1000cc injectors in Victoria?
What turbo setup etc?
Most tuners are happy to use what you have and will tune it to a safe limit...
Take a drive to Racepace in Bayswater.
Plazmaman plenum, gtx3076 .82 externally gated 6boosy highmount and power fc. Similiar setup to your's 34GeeTeeTee.
Sweet! Maybe give Racepace a call as Ash said... I have spoken to them a few times when getting a radiator and they were super helpful...
The turbo will go over 350kw but depends how hard you want to lean on it ;) Keep me updated with results if you can, very keen to see!
Thanks ill check them out
Sweet ill keep you posted!
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
