Hey guys so I'm having some sort of boosting issue with my 32 RB20.
Setup is
RB20 - 71 000 km
stock turbo
3 inch turbo back exhaust
Turbosmart Dual stage boost controller - apparently set to 12psi
Unknown aftermarket brand side mount intercooler
Apexi Pod filter
Aftermarket boost gauge setup behind steering wheel
Apparently stock BOV plumbed back - The induction noise is pretty loud and so is the flutter so not sure, but could just be because of the Pod ?
Ok so problem started last few days, first I noticed the boost gauge seemed to give off some odd readings (going right down to -30psi on deceleration, idling around -20psi then spiking up to 15-16psi on WOT).
Then yesterday I heard a strange induction sound on acceleration.
Pretty much car doesn't sound like its building boost smoothly, induction noise is very choppy especially WOT, best way I could describe it is, sounds similar to compressor surge.
Also it feels like its down on power a bit, especially past about 4000RPM.
SO just looking for some advice, what could be causing this? Could it be a boost leak somewhere in the system and where should I start looking and what am I looking for?
First turbo so advice appreciated thanks
*UPDATE* Just got car up on ramps, theres a stick wedged in between some of the fins of the intercooler not the whole way through but yea probably could be leaking, would this be causing all the issues?
Edited by WRO
https://www.sau.com.au/forums/topic/429909-rb20-boost-issue/
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
