Due to work commitments, I am about to start parting out my DR30 project, with alot of parts available, is there much interest from anyone in WA for anything?
I really can't be bothered shipping anything large interstate. Most parts are brand new.
Parts include;
Iron mask front end
Vented FRP Iron mask bonnet
Jenesis FRP front lip and side skirts
Jenesis FRP front bumper (needs repairing)
8 point bolt in cage from Japan.
Complete interior (minus seats) with several brand new parts from Nissan. Uncracked dash.
Recaro seats with mesh head rests and R30 rails.
Jenesis 260 km/h speedo with 10,000 rpm tacho
Front and rear windscreens
Brand new coupe rear lower chrome window trims.
Jenesis oil cap and gear knob
If anyone in WA is interested, the shell (unregistered) is available as well, can do a deal if anyone wants the shell and all the parts. Shell is currently in 2 pac primer.
At this point in time the engine and gearbox is not available.
Cheers,
Steve
Edited by masTers
https://www.sau.com.au/forums/topic/429919-any-r30-coupe-owners-in-wa/
Willing to ship, bulky items you will have to organize shipping yourself (to the point of having someone pick it up from my place as I am too busy with work to drop it anywhere)
Edited by masTers
Will send the front bar if you are patient with me in getting it shipped.
I am happy to wrap it in bubble wrap or cardboard, if you can organize to have it picked up from me (Dianella 6059 for reference)
IF it needs to be dropped to a depot, It could take some doing, but not impossible. I am in the middle of busy season at work so for large items I am quite time poor.
I am willing to post the rear moulds (assuming this is what you mean?)
The following parts are gone;
Iron mask front end
Jenesis FRP lip and skirts
Grey tail lights
Shell is gone but the Body Loom and engine harness are still available (no ECU)
Edited by masTers
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
