I ran a stock internal to 450rwhp for years.  Tracked it, hillclimbed it, drove it on the road. It was fine.  Then I had it rebuilt and it all turned to custard.
If you can live with it off the road for 6 months then just use it up with the stock internals.
20 years of unknown history running at 10psi, boost it to 22psi....you better be ready.....it's a gamble doesn't matter which way you look at it. As long as the OP is aware that you are increasing the risk of something going wrong. And it is far cheaper than what you are suggesting and having an engine fail and paying for labour and turbos again.
  • 4 months later...
Couple of quick pictures
Plasti-dipped front bumper.
List of stuff had done by Josh last time:
Bcbr coilovers fitted
Work Meister s1r 28x10 +12 fitted
Archilles 123s 265x35x18
Blitz front pipes
Front and rear camber arms
Rear castor arms
Replaced busted CV
Serviced all the usual suspects
Twin plate coppermix fitted
High flow panel filter
The difference in response the clutch and flywheel is insane feels like a more powerful different car even with no power mods as yet.
Next up is:
Front r34 brembos
Rear castor arms
Braided lines
New pads
Rear sway bar
Front and rear strut braces
With the handling all taken care of I'll start building towards my power figure.
Would like to take this opportunity to thank and recommend josh and the team at galvsport I couldn't be happier.
  • 5 months later...
Next up is:
Front r34 brembos
Look at the Alpha Omega EVO brembo brake upgrade with 350mm discs, the bolts for the 34 brembos are 14mm against 12mm for the 32 ones so they don't just bolt on
^^ This!
If you want Brembo's, get a set of R32 GTR V-Spec / V-Spec II or R33 GTR calipers as they will be a straight fit and bolt on.
You will have to custom make, the R34 GTR Brembo's fit.
The GTR Brembo's are good for street and light / occasional track work but if you want to seriously track your car, look into a set of aftermarket race caliper setup.
Copy Paste from another forum.
Right here is the full list of work done this round anyway,
Engine :
Garrett 9-s
Mines Ceramic Coated Dump Pipes
Vipec V88 ecu
Blitz radiator
HKS cam gears
Tomei Type B 260/260 9.15 pon cams
DW1200 injectors
Splitfire Coilpacks
Walbro 465 E85 pump
Rips Sump Kit
Oil pump Billet gears sourced locally
ATI 1000hp harmonic balancer
Major service
Misc:
Project MU pads up front
Valley and Cam covers painted wrinkle black
Plenum soda blasted
New R34 valley emblem
Cusco brake cylinder brace
Removed clutch vacuum assist lines
Lifted car 20-30mm
New heater hoses/gaskets bolts and various other parts you would expect
Run new wiring relay to pump as stock had a current drop
Thats all the major stuff, the budget was added to significantly as decided to take the advice of josh and many of you guys here in regards to tackling the oiling issues early, sump, pump gears and harmonic balancer were extras that required engine out, it worked out fine in the end since reduced a little labour in other areas and gave me the chance to soda blast the horrible flaky intake plenum paint and paint the valley/cam covers.
Only spoke briefly to the tuner (Sean at ASG) but was as you would expect, made 470hp and turbos ran out of breath in top end which suits me fine when the original build brief was formed. Aimed for response and midrange, from the look of the graph and the very short spin I took in it today its within those parameters.
Still cruises around in traffic perfectly happily off boost and clutch feel is only slightly heavier so still very easy to daily drive. I am in love with the new idle/exhaust note though, good amount of volume without being ridiculous.
Will post the Dyno results when I get them and after have a debrief with Josh as to how it all went as he was busy today when I took it for a quick test.
Plans for future are for one to enjoy it and get it onto some track days to stretch its legs and learn to drive it but the main priority is to get the exterior to immaculate, so ill find some nismo rear pods, fix a few tiny dents and do a few small things.
Still smiling ear to ear haha
  • Like 1
Here's the dyno.
Full boost a little later than had hoped but tuner did say could move curve a bit so somewhere down the line may look at trying to get 18psi by 4k.
Stoked with power figure though.
Edited by Ambi3nce
  • 5 months later...
Quick update, went in for retune to swing cams to bring boost on earlier.
Dialed in 20psi over previous 18psi. Gained 2HP, 30+nm torque and boost is on almost 700rpm earlier. Very happy with how it is now, I would not have though that 500-700rpm in boost earlier would make such a difference, but it feels night and day.
Also got launch control set up for vipec so I can not fail miserably at the drags when I eventually get down,
IMG_20141128_201521_zpsk4ib5kz_edit_1417
Nice and strong. Must be nice to drive on the street and should be a blast on the track. Good stuff mate.
Yeah the retune made a huge difference, I did not think 700rpm would feel so different but it so much better on the street, havn't had a chance to track it yet. Blew a cooler pipe today for first time so may have to start swapping out some old pipes for newer ones/clamps.
Neat and tidy build congrats and enjoy.
Thanks man, that is the plan. Next break from work will get some small tidy up jobs done, tints to try protect the interior from the ridiculous heat here and getting some small dents removed.
700 rpm is night and day. 200 rpm is heaps!!!
Area under the curve just makes the car so much nicer to drive!
Nice build thread mate. Car looks clean, the wheels suit perfect! Awesome power delviery too.
What's the next plans for the car?
Thanks man,
Next is a few small things, tint, few small dents removed, basically get it as good as I can short of a respray.
Need to buy and install a defi 3 gauge cluster as I want oil/coolant temp and boost pressure which exceeds stock gauge.
Also will be replacing the Gsensor with a digital unit as mine is starting to read a bit off and is throwing the torque to the front at strange times.
Yeah Its so much more fun to drive now, feels alot quicker too
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
