i bought r34 tomei poncams cams because they wre cheap, so i decided to put them into my r32. was told they would work with a r34 CAS and abit of wiring work.
got the car to start, it idled for about 1 hour, but when i turned it off it wouldnt start again. i cranks but wont turn over.
HELP?!
engine was just put in, not sure what to check.
the reqirint work is simply reversing the wiring on the CAS plug.
any information would be appreciated!!
https://www.sau.com.au/forums/topic/429964-r34poncams-in-r32-issues/
HELP?!
what engine?
I've never heard of putting 34 poncams in a 32. Its not something that logically sounds right but I cant be sure it doesn't work.
r34 cas on an r32 ?
You idled it for an hour ! - why?
Tried putting it back to the way it should be
Then go through the process of - Why my car wont start
Hopefully no damage has been done that cant be undone.
Edit: Good point ^above. Suppose if its an R34 RB25 engine - sweet. If it's an RB20 DET :wacko:
Edited by Sinista32
thanks for the help guys, its an rb26 btw.
all good im ripping out the poncams n getting r32 ones. i got an r32 cas so itll b wired up properly again. hopefully nothing major is wrong with it. fuc kme dead. LOL
Mechanic let it idle for 1 hour and took it around the parking lot. do u think any major damage has bee n done?
  • 2 months later...
Can't see thread tags on phone. It's my understanding that you should not let a new cam idle, it should be run at around 2000rpm for 20 minutes to run it in. Not sure what Tomei recommend.
+1 Running in a new camshaft requires fast idle for approx 20min (or whatever the manufacturer recommends), then varying load i.e. hills hills & more hills. This also good if it's an overhauled engine, for bedding in rings (low RPM, wide open throttle - to force the rings into the liner).
  • 3 weeks later...
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
