After the last EOI (http://www.skylinesaustralia.com/forums/topic/416591-eoi-simworld-2013/#entry6688024) died I'd see if we can organise another SimWorld event!
So - We (SAUWA) is thinking of holding another Social Event at Simworld in Carousel after the huge success of the previous events. Everyone had a great time at the last couple events although there have been a couple inflicted with motion sickness so its quite a ride
For those who don't know what SimWorld is check it out at http://www.simworld.com.au/ These are full simulators, where you get thrown about etc, nothing like anything you've done before.
The general format of the event is:
Group 1 - 5min Practice - Course 1
Group 2 - 5min Practice - Course 1
Group 1 - 10min Race 1
Group 2 - 10min Race 1
Group 1 - 5min Practice - Course 2
Group 2 - 5min Practice - Course 2
Group 1 - 10min Race 2
Group 2 - 10min Race 2
Group 1 - 5 min practice - course 3
Group 2 - 5 min practice - course 3
Group 1 - 10min Race 3
Group 2 - 10min Race 3
Final - 15min Race (combined results from Race 1, 2, 3 & 4 will determine who is in the finals)
* Minimum race time should be about an hour
** Comes with food supplied by Nandos or we can have pizza plus we can have BYO drinks
*** Group size is 9, as there are 9 Simulators
Note:
The costs approximately $65 if we choose nandos or pizza or $50 without food but I would imagine majority will want food so everyone will have to pay $65
The a full race simulators, not simple arcade games, so it will definately be an experience.
Friday nights we will get the longest time on the machines for our money and its been convenient for most people in the past. Maybe the 13th or the 20th of September might be a go-er?
Please register your interest ASAP, so we can make this event happen. Please invite family members (friends, wives, older kids etc), as all Simulators are equal, and doesn't require a drivers license We'd like to have this filled with SAUWA Members and there familys/friends, but seeing as we didn't get enough interest I'll open it up to the rest of SAU from the get go.
So far
* Trevz
* Lachy (Hank Scorpio)
* Gary
* Damo (Frosty)
Cheers
Hank
Edited by turboedsloth
https://www.sau.com.au/forums/topic/429982-eoi-sauwa-simworld-racing-night/
Btw hanky they didn't have skylines available last I heard
:O
What happened to our R34 race at Tsukuba!?!
Anyway I'm confident of numbers now, will try and contact SimWorld this week :)
Sorry about the lack of replies guys, that's completely my fault, I do apologize.
http://www.simworld.com.au/contactus.aspx
"We have moved the machines down to the Albany Amusement Centre (formerly Albany Ten Pin Bowling)"
So SimWorld seems to be a no go, any other ideas you guys would like me to look into?
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
