Gents & Ladies.
12.30 p.m. to 5pm drive day at the creek. $100 if we get 15 people and we should, $120 for less. Full face helmet long sleeve tops and bottoms. Spectators OK, passengers OK, no cost.
Any more questions please post for an answer.
Be there or do the speed limit.
https://www.sau.com.au/forums/topic/43-eastern-creek-drive-day-16th-may/
  • Replies 112
I have a small list of things to do to my car before it goes on the track, if I can get these done then i will be there, otherwise i will be spectating only.
The List;
[list:3014123954]
[*:3014123954]Fuel Cut Defender
[*:3014123954]wound up to 12 or 13 psi
[*:3014123954]speed cut removed
[*:3014123954]cold air induction fixed up
[*:3014123954]4pt harness put in
[/list:u:3014123954]
Then i'll be there!! :D
He's got a point, comon Prank ..... I mean, what are all those mods anyway without a pit crew wearing schmick overalls with your name and sponsors badges plastered all over them ....
or maybe .... your jusst .... CHIKEN :wink: burrrkkk .. brrrkk brrkkk.. /end poor chiken impersonation.
Well,
Its looking good, 20 + people so far.
1. Oz GTR
2. Zane GTS
3. Peter CRX Honda
4. GTR-51K GTR
5. Dflash GTS
6. Silver Arrow GTR
7. + Friend
8. + Friend
9. Bonks GTS
10. Dazsta WRX
11. + Friend
12. Zoran GTR R34
13. Simon GTI Pulsar
14. Roy GTS
15. +Friend S14
16. +Friend Merc
17. Red900SS GTS
18. + Friend RX7
19. Duncan GTS
20. Jimbo GTS
21. Prank GTS
22. Greg 911
23. Shane XR8 Ute
24. Evan VR V8 Ute
25. Gts32t GTS
26. John WRX
27. Akira GTS
28. Fats GTS
29. Majanal GTS 50% atm
30. PH GTR 50% atm
Guest gts32t
Ello gents new to this forum, so ello ello everybody. I am very keen on this event, is the price any cheaper the more cars that attend? I will be bring a R32 GTS-t - very special specs, just like Prank I have a hell of alot of bolt on bit in the garage that need to go on before the track day but this should not be a problem, and I should be ready.
GTS 32t,
We already have a discount rate of $100, the usual price is $135 per car or $125 for 3+ or my deal which is $100 for 15 or more. At the moment we have well over 20 people so as long as everyone turns up we will be driving at $100, but bring $125 incase 50% of the people pull out at the last minute.
Guest gts32t
GTS 32t,
We already have a discount rate of $100, the usual price is $135 per car or $125 for 3+ or my deal which is $100 for 15 or more. At the moment we have well over 20 people so as long as everyone turns up we will be driving at $100, but bring $125 incase 50% of the people pull out at the last minute.[/quote:8ce458ef55]
When do I have to give my final notice that I will be coming.
GTS 32T
As it stands you are down as coming, just let me know if you can't make it .
With the numbers we are getting it looks like we will have 2 skyline groups, fast and slow. Finally what looks to be a great turnout, bring it on.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
