  • Replies 112
The final list
1. Oz GTR
2. Zane GTS
3. Andrew RX-7
4. Dflash GTS
5. Silver Arrow GTR
6. + Friend S14
7. + Friend S15
8. Bonks GTS
9. Dazsta Friend
10. Zoran GTR R34
11. Simon GTI Pulsar
12. Roy Friend S14
13. Roy Friend Merc
14. Red900SS GTS
15. GSI
16. Duncan GTS
17. Prank GTS
18. Mal XR8
19. + Bro VT V8
20. Gts32t GTS
21. John WRX
22. Fats GTR
23. Evil GTS
24. Urmine GTS
25. Exsist GTS
All, sorry about not being able to get everyone on, but it should be a good day. I was going to break the group up into the following.
GTR's 5 of them to drive in the fast group.
GTS's 11 of them in the SYkline group. I will include the 3 V8's, S14, Merc, WRX & RX7.
All the others can drive in the slow group. I.E. GSI, GTI
Well, no need to answer your question Prank, but any way yes the day is still run in the wet, unless Dave has called it off the day before. Anyways Its almost 7 am and the sky is clear and blue. See you all there there around lunch its time to unleash the Fire Blade to good old eastern, see you out there, Im the one with the smile on my face.
By for now
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
