Hi there, I'm new to this forum..I have a few issues with the plenum/injector seals! I have a top feed setup with top feed Bosch injectors. The plenum came with 6 little bosses for top feed injectors. I have put the o rings on these and put the o rings on the injectors! The metal bosses are loose as buggers! I have been told to buy gtr seals and get the metal collar on each injector machined to allow the seals to go into the plenum with the injectors. This also means I will have to shorten the fuel rail spacers lowering the height of he rail..is there any other way of fitting top feed injectors creating a seal?
Thanks for any info
Stef
https://www.sau.com.au/forums/topic/430012-gtst-freddy-plenum-help/
Yes.
I can possibly supply you with the correct lower Orings, why they weren't supplied to you in the first place is the main issue. Did you tell the supplier they were for a GTR? I would have thought a GTST plenum would allow GTST injectors to drop in...
Perhaps I don't understand exactly what your issue is... Can you take a pic?
