Hey guys, got some parts people here may be intetested in
Blast pipes
http://www.gumtree.com.au/s-ad/woodville/other-parts-accessories/3-drift-blast-pipes-s13-200sx-180sx-nissan-exhaust/1024709222
r32 shell-wrecking
http://www.gumtree.com.au/s-ad/woodville/wrecking/r32-skyling-rolling-shell-will-wreck/1025003198
s13 door
http://www.gumtree.com.au/s-ad/woodville/auto-body-parts/180sx-s13-silvia-passenger-door/1025004251
also have 180sx tail lights $25
Whits s2 r33 guards $200 pair
s1 r33 4 door dash $50
R33 s2 door trims $50 pair
r33 s2 rear quater trims $50 pair
r33 s2 airbags and steering wheel $150
[email protected]
0449669476
  • 4 weeks later...
Still have this shell in the shed taking up too much space, have now removed interior, passenger door, bootlid, few other bits, asking $600 ono, make an offer, needs to go this week or will be getting scraped, make an offer!
Also, if anyone wants the bare shell to repair damage etc. I'll take $50 for it, radiator support panel is worth more than that....
Do you have the interior panel where the rear seat belt goes the one by the window. Not sure what is the proper term for it. Will you be willing to ship to japan/ apo/FPO address? The ones here they are asking 120$ USD per side ;(
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
