R33 Gtr 1995, White
Hi all,
I have an White r33 gtr for sale, 112,xxx klm on the clock.
When I got the car the bottom end was stuffed so I am in the process of building another engine for it.
Another bottom end has been used with a fresh rebuild, (rings, bearings, hone, new seals, reshimed head, gates timming belt).
The car has r33 gtr wheels on it with new tyres (245/45). Coil overs, boost guage, and 3.5" exhaust with tuned y-pipe and split dumps.
Stock turbos that have been port matched with the manifolds,
car also has an aftermarket front bar, (not sure what brand), and H1 HID lights (low Beam).
The engine is still being put together at the moment and will be run in before sale.
If any one is interested in the car and would like to see the engine before its is complete you can contact me and we can arrange something,
im asking $20,999 ono with rego and road worthy.
Located in Brisbane.
Thanks
Some more details
Acl race series bearings used on both big end and mains.
Oil restrictor in block.
Standard oil pump
Standard water pump
Standard Rb26 Pistons and Rods, with Genuine Nissan rings.
New gaskets and seals.
All valve stem seals replaced.
Valves reseated into head.
Head decked.
Block honed
Standard head gasket.
Gates timing belt.
Stock injectors and computer.
Hks Tuned length y-pipe
Split dumps,
3.5 to 4" exhaust
Tanabe Coil overs, fully adjustable.
Pivot boost gauge
Excellent condition interior.
Brembo brakes.
Pics are on there way...
  • 1 month later...
Hi all, bit of an update.
Car is running and will be registered this week then off to the dyno for a run in.
still waiting on a few parts to finish it of but I am still open to people coming to have a look if they are interested.
Hi all,
More pics are coming soon, waiting on a new front grill, and a polish.
I will be open to offers including cars for trade.
I would be open to 4 door 4 cylinder cars preferably turbo. (eg, WRX, Evo, GTIR, VW GTR, Liberty or A4 Audi.)
I will def consider others also.
thanks
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Hey mate was just wondering if you were considering swaps?
2005 bf xr6 turbo. Has 320rwkw, 6 speed sports shift auto, clean, has almost 160000km comes with spool rods, cp pistons, arp studs, big actuator. Has a full exhaust, valve springs, injectors, fuel pump, oil feed line, zip kit in gearbox for firmer shifts, DVD player installed but haven't made the appointment for it to be wired up yet, gauges on dash, plazman 800 cooler, hot side cold side pipping, currently running on 13psi. If motor is built (parts supplied) it will handle 1000hp claimed by spool. Vic rego until November.
  • 3 weeks later...
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
