Hi all,
I have an White r33 gtr for sale, 112,xxx klm on the clock.
When I got the car the bottom end was stuffed so I am in the process of building another engine for it.
Another bottom end has been used with a fresh rebuild, (rings, bearings, hone, new seals, reshimed head, gates timming belt).
The car has r33 gtr wheels on it with new tyres (245/45). Coil overs, boost guage, and 3.5" exhaust with tuned y-pipe and split dumps.
Stock turbos that have been port matched with the manifolds,
car also has an aftermarket front bar, (not sure what brand), and H1 HID lights (low Beam).
The engine is still being put together at the moment and will be run in before sale.
If any one is interested in the car and would like to see the engine before its is complete you can contact me and we can arrange something,
im asking $20,999 ono with rego and road worthy.
Located in Brisbane.
Thanks
https://www.sau.com.au/forums/topic/430065-r33-gtr-1995-white/
Some more details
Acl race series bearings used on both big end and mains.
Oil restrictor in block.
Standard oil pump
Standard water pump
Standard Rb26 Pistons and Rods, with Genuine Nissan rings.
New gaskets and seals.
All valve stem seals replaced.
Valves reseated into head.
Head decked.
Block honed
Standard head gasket.
Gates timing belt.
Stock injectors and computer.
Hks Tuned length y-pipe
Split dumps,
3.5 to 4" exhaust
Tanabe Coil overs, fully adjustable.
Pivot boost gauge
Excellent condition interior.
Brembo brakes.
Pics are on there way...
  • 1 month later...
Hi all, bit of an update.
Car is running and will be registered this week then off to the dyno for a run in.
still waiting on a few parts to finish it of but I am still open to people coming to have a look if they are interested.
Hi all,
More pics are coming soon, waiting on a new front grill, and a polish.
I will be open to offers including cars for trade.
I would be open to 4 door 4 cylinder cars preferably turbo. (eg, WRX, Evo, GTIR, VW GTR, Liberty or A4 Audi.)
I will def consider others also.
thanks
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Hi all its been a while.
Price drop to $19 900. to any one interested I will look at offers also.
Just had a rear wheel bearing replaced also.
Edited by Muff
Hey mate was just wondering if you were considering swaps?
2005 bf xr6 turbo. Has 320rwkw, 6 speed sports shift auto, clean, has almost 160000km comes with spool rods, cp pistons, arp studs, big actuator. Has a full exhaust, valve springs, injectors, fuel pump, oil feed line, zip kit in gearbox for firmer shifts, DVD player installed but haven't made the appointment for it to be wired up yet, gauges on dash, plazman 800 cooler, hot side cold side pipping, currently running on 13psi. If motor is built (parts supplied) it will handle 1000hp claimed by spool. Vic rego until November.
  • 3 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
