R33 Gtr 1995, White
Hi all,
I have an White r33 gtr for sale, 112,xxx klm on the clock.
When I got the car the bottom end was stuffed so I am in the process of building another engine for it.
Another bottom end has been used with a fresh rebuild, (rings, bearings, hone, new seals, reshimed head, gates timming belt).
The car has r33 gtr wheels on it with new tyres (245/45). Coil overs, boost guage, and 3.5" exhaust with tuned y-pipe and split dumps.
Stock turbos that have been port matched with the manifolds,
car also has an aftermarket front bar, (not sure what brand), and H1 HID lights (low Beam).
The engine is still being put together at the moment and will be run in before sale.
If any one is interested in the car and would like to see the engine before its is complete you can contact me and we can arrange something,
im asking $20,999 ono with rego and road worthy.
Located in Brisbane.
Thanks
Some more details
Acl race series bearings used on both big end and mains.
Oil restrictor in block.
Standard oil pump
Standard water pump
Standard Rb26 Pistons and Rods, with Genuine Nissan rings.
New gaskets and seals.
All valve stem seals replaced.
Valves reseated into head.
Head decked.
Block honed
Standard head gasket.
Gates timing belt.
Stock injectors and computer.
Hks Tuned length y-pipe
Split dumps,
3.5 to 4" exhaust
Tanabe Coil overs, fully adjustable.
Pivot boost gauge
Excellent condition interior.
Brembo brakes.
Pics are on there way...
  • 1 month later...
Hi all, bit of an update.
Car is running and will be registered this week then off to the dyno for a run in.
still waiting on a few parts to finish it of but I am still open to people coming to have a look if they are interested.
Hi all,
More pics are coming soon, waiting on a new front grill, and a polish.
I will be open to offers including cars for trade.
I would be open to 4 door 4 cylinder cars preferably turbo. (eg, WRX, Evo, GTIR, VW GTR, Liberty or A4 Audi.)
I will def consider others also.
thanks
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Hey mate was just wondering if you were considering swaps?
2005 bf xr6 turbo. Has 320rwkw, 6 speed sports shift auto, clean, has almost 160000km comes with spool rods, cp pistons, arp studs, big actuator. Has a full exhaust, valve springs, injectors, fuel pump, oil feed line, zip kit in gearbox for firmer shifts, DVD player installed but haven't made the appointment for it to be wired up yet, gauges on dash, plazman 800 cooler, hot side cold side pipping, currently running on 13psi. If motor is built (parts supplied) it will handle 1000hp claimed by spool. Vic rego until November.
  • 3 weeks later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
