Hi all, just a little info about me :)
Name's Blake and Im stepping into the JDM world. I have been primarily focused on the ford 4L inline six, and while its a great platform for easy reliable power it was inevitable that the high revving nature of the Jap inline 6s would eventually take hold on me.
My daily driver is a 400rwkw 6sp auto xr6turbo.
My project is a turbo Ef falcon 5sp.
so now onto why I am here, I recently purchased an r34 GT4 from a mate, the car has been kitted out with anything retrievable from his wrecked 33 gtr.
-RB26, forged internals, nitto gaskets etc etc
not sure about oil pump but it does have an enlaged oil drain in the head.
HKS 264 cams
HKS cam gears
HKS GTSS twins
3inch catback with stock dumps (got dumps on the way)
Trust oil cooler
Fuel system:
Sard billet fuel rail
Turbosmart adj reg
sard 1000cc injectors
twin braided fuel pressure lines and single oversize return
twin intank walbro pumps with relays
Haltech platinum pro with EFLEX e85 sensor.
r33 gtr brembos
Koya r-1 245-30-19 fronts and 275-30-19 rears
r34 gtr rear wing
Basically the car got defected, my mate spent 8grand on the fuel system, ecu etc getting it all legit and passed emissions.
when it was time for the e85 power tune the tuner said he heard a noise and was worried about a spun bearing.
so I offered my mate 6k for the car and he regretfully said yes.
the car was fine to drive around with no rod knock.
however, on cold start only while the oil pressure light was one you would hear a series (maybe one seconds worth) of knocks
factory oil pressure guage seems to be semi retrarded so I fitted a mechanical autometer guage, 60psi at 4k cold but after the oil heated up the pressure was only 10psi at idle. I can hear a very slight knock so I have decided to pull the motor to avoid a potential for legs leaving the bed etc
Now I have done a fair amount of research on oil systems for the rb26. That doesn't make me an expert so I would like to list me plans and see what you all think.
Billet N1 pump $350
n1 housing $350??
ACL race series bearings
now I am unsure of whether It is really necessary to go for an extended sump or just the tomei baffles??
I plan on doing hill climbs, track days etc. the car wont be stripped out.
I already have the Oil drain in the head enlaged, I couldn't find receipts for which pump went in when it was rebuilt (3000km ago)
sump will be overfilled for track work. and if I can get away with only the baffles I will be much happier keeping the extra grand for other things
Im going to have a crack at removing the motor myself, looks like a PITA, rebuild it myself and go have fun :)post-117959-0-92601700-1376206934_thumb.jpgpost-117959-0-42270900-1376206948_thumb.jpgpost-117959-0-76854400-1376206953_thumb.jpgpost-117959-0-72476100-1376206965_thumb.jpg
https://www.sau.com.au/forums/topic/430073-r34-gt4-rb26/
  • 4 weeks later...
update,
Got my N1 pump from the sates, replaced the N1 gears with a billet set.
Managed to get my hands on a modified turbo outlet pipe, hopefully the baffles give me a nice little bit of response.
I'm hoping to get the most out of my little GTSS turbos.
Plans while the motor is out:
Fix the coolant passages in the head.
,Bearings and does anyone recommend further crank balancing? and how necessary is a nice harmonic balancer?
looking to limit revs to 8500rpm, cams are hks 264/8.7s
most other things should be pretty good since its such a new motor (touch wood)
Tomei sump baffles.
Im assuming that r32,33 and 34 exhausts are fairly similar and would fit either car? have a 3inch but am looking for a 3.5inch if anyone has one nearby (Newcastle)
https://www.sau.com.au/forums/topic/430073-r34-gt4-rb26/#findComment-7009160
Haha that's alright mate :) Ill definitely post some more pics up when I get a chance! I'm thinking of getting some ROTA grids for it and selling the koyas. Not sure what the max width I could go on the front wheels would be. But ill be happy with getting rid of these wheels and dropping my coilovers to a cop friendly but clean height :)
https://www.sau.com.au/forums/topic/430073-r34-gt4-rb26/#findComment-7014738
Yeah I know Koyas are better design but I'm not a big fan of 19s on my car. I'd rather a nice set of 18x9 ROTAs . They look good to me and I won't be jumpin ripple strips every day haha. It's mostly for looks. I might go with painting my 33GTR wheels black to start with
https://www.sau.com.au/forums/topic/430073-r34-gt4-rb26/#findComment-7014791
  • 1 month later...
Update,
picked up a few buts and pieces.
Tomei Sump baffles.
N1 oil pump housing with Billet gearset.
HKS 2540s with split dump pipes,
HKS 3.5in legal exhaust, (will be fitting varex muffler after I pass noise test.
ARC twin entry cooler.
engine was a bit of a struggle as im not the smallest bloke and found access difficult. starter motor wtf???
looking for around 400awkw or so on e85 but not fussed if Its less :)
time to change bearings and check tolerances :) then tune time!
https://www.sau.com.au/forums/topic/430073-r34-gt4-rb26/#findComment-7102084
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
