hey guys i had a overheating issue with my 33 gtst. it caused my head to crack. i originally thought it was my head gasket. the car was built by previous owner. so i dont know all about it. ive by told by a few ppl on here that im running a forged piston, i was also told it was 40 thou over sized too. ive added a pic of my piston so u can check it out. i pulled my head off and found out i was running a mls gasket. so i didnt blow that as i assumed first. ive chosen to go back to the standard hg but realised that my pistons stuck out a tiny bit when the motor was at TDC. i looked at my mls gasket and realised that it was like 4 or 5 layered so its pretty thick.
anyways.
my question is when i put a breaker bar on my crank bolt to see if it all rotates freely i kind of feels like that pistons are tapping the valves or hitting the head. ive got a second hand head and had it cleaned up, so its not the same head.
was my old head gasket that thick for clearance or what?
ill take photos of my old hg and measure it so u guy can see. any help would be good. originally when i bought the car the guy told me its a 2.7L stroker but i assumed he was full of it.
cheers cuong.
https://www.sau.com.au/forums/topic/430093-help-with-valve-clearence/
Measure piston height at TDC, align the cam gears with the marks on the backing plate (TDC head alignment) then you shouls be able to measure how far your valves stick out at TDC. Work out the clearance from valve to piston then buy head gasket to suit
Head gasket thickness is crucial on a built engine especially with a positive deck height. I wouldn't have put a thinner one on but I don't think that would actually cause the valves to hit. Have you triple checked the cam timing?
With any interference engine you should never turn cam and crank separately fully
That's asking for bent valves
Have cams out first allign crank to tdc then install cams to tdc and attach timing belt or you can
Have the crank just before tdc 20 so all the pistons are slightly down and then rotate the cams to tdc and then bring the crank to tdc and attach belt
If you have the crank just before tdc 20 you can rotated the cams all you like and it won't touch the pistons
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
