Hey guys so my r33 switch light dims when i close the door rather then turning off! And when i open the door the light brightens anyone else had this problem! Issue cause its snnoying having to turn the light on when getting inside the car so i can see at night!
https://www.sau.com.au/forums/topic/430127-help-r33-s2-roof-light-switch/
They all dim when you close the door. I don't get what you mean by the light brightens when you open the door? Does the light turn on straight away or it takes a while to get bright?
It sounds normal to me.
About 10 seconds. I will look at a wiring diagram and see what I can find. It could be high resistance across your door switch or the control module.
Also interior light has three settings, "Off", "On", "Door", make sure it's only set to "Door" and not "on" all the time...
If at "On" it may not be full brightness as it may have not so good of a ground, when the door open it brightens as the door allows a better flow of electricity.
Replace the globe/s or LEDs and while your there take the whole unit out of the roof. While out make sure all the contacts are fine.
- Disconnect the wiring harness from the back of it and then re-insert it. You could quickly clean the contacts it plugs into.
Taking it out is easy. Gently pry the clear plastic off. Inside is 2 screws - remove. It'll drop down. Unclip it. Clean contact points and replace globes.
Clip together and test.
2-5 minutes.
Edited by Sinista32
^^^^ That would help if it didn't work at all. The light does come on so that proves the circuit is working and the contacts will be clean. If the contacts were dirty then you would have no light at all
Wiring diagram.doc
Hope this helps does it turn off once the car is started or the key is in.
I still believe its the entry control unit
There will a constant 12v on one side of the globe and the control unit will supply the other side with a negative via the doors which has to go through the C/U
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
