Sydney Wreckers And Engineers/rego Questions
By drifter17a · Posted
Does power steering have a cooler? pump is right next to the pump and as I understand r34 hicas is electric so unsure why all that loop going to driver side from the pump where the pump is on passenger side( uk based) Below seems to replace the entire hosing with this kit https://www.jdmgarageuk.com/jdmgarageuk-power-steering-line-kit-for-rwd-nissan-skyline-r32-r33-r34-silvia-s13-s14-s15.html?gad_source=1&gbraid=0AAAAAqLt7fNuZgXNepjqk8I-qovXgmJCu&gclid=Cj0KCQiA_9u5BhCUARIsABbMSPtHrfTutOf0ROkDV6lb7BQO-dqh2AMpqlyvTw7ncRMMkHjDIICIoA8aAiaZEALw_wcB -
Cobbers and Bullets were 1 cent each when I was a youngster
Just checking, is there still and AFM and then leak free intake piping to the plenum? that would kill it if it not. An unloaded turbo in the exhaust won't cause an issue, it you are worried just disconnect the wastegate so it is open
