Hi Guys,
Can anyone tell me is the vin / chassis number ONLY located on the firewall in a BNR34?
I have a 2002 S15 and it is stamped on the radiator support panel as well. My GTR has it clearly stamped on the firewall and nowhere else im jus thinking hope it wasnt involved in a front end prang even though it all looks perfect and was inspected buy an RACV mechanic but doub't the dude would have picked that up if it had of been? :closedeyes:
Cheers :)
Edited by yeahmate
https://www.sau.com.au/forums/topic/430166-r34gtr-chassis-vin-details/
Also planning on building a 3 litre bottom end for it - For those who have done this have you restamped the new block with your orignal numbers? or just left the ones on new block on there? Cbf with hassles from the jacks if i get pulled over and they start to break balls :verymad:
Edited by yeahmate
I've only ever seen it on the firewall, factory 30 engine number, unless they know what to look for they can't really tell it's a 30
look at a high deck kit and use the factory 26 block, I have nearly finished a RB2630 build in my 34 and am looking at pulling it out and doing a high deck setup for clearance reasons
ah sweet i just thought whats the chances i get pulled over and vic police start checking engine numbers? ive had gtr's, xr6 turbo's 200's and never had any issues with them going that far. what you want for the bottom end? why the clearance issue? i thought 26/30's were a popular build
i'm going to finish this one then build the high deck over time using the factory block
i'm using the platinum sump adapter which is 1/2" thick leaving 5-6mm between sump and cross member and no possible way of using bottom gearbox bolts
i lowered the cross member 8mm, used RB25 piston shaving block down to 0 deck height and cant fit standard strut brace without washers lifting it up to clear twin turbo pipe and had to space bonnet up to clear catch can that sits on top of engine
they are i'm just anal about how things fit and go back together and as I use this car for track use these are thing I want to be spot on so I know when I go full on through a corner I don't have in the back of my mind some thing that might go wrong
don't muck around, if you want a 30 bottom end contact RIPS, I did all the spanner work on my one myself and I reckon I saved maybe $2000 from the quote I was given from them, but the messing around wasn't worth it
then drop your head on it and enjoy
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
