I have my GTS4 in fixing the rack ends, my mechanic tells me the (front) tie rods also need replacing (only to be expected in a 24 year old 240 k car). He apparently got sent the wrong ones, and has been told the correct ones are only available "genuine" - @ $185 EACH from Nissan. :woot:
I need to know if there are aftermarket ones available at a lot less than Nissan charge. In Melbourne.
TIA
Edit: it's a 1989 model, if that makes a difference (which it seems it does).
Edited by blind_elk
https://www.sau.com.au/forums/topic/430178-tie-rod-ends-r32-gts4/
Wrong length, from what I could gather from my mechanic. (can't remember if too short or too long).
This is the GTS4, not GTSt.
Should grab the old ones in the morning before I start talking to Nissan dealers.
Found these:
http://www.ebay.com.au/itm/OEM-2-FRONT-OUTER-TIE-ROD-END-NISSAN-SKYLINE-GTR-R32-R33-R34-RB26-/110919715816?pt=AU_Car_Parts_Accessories&hash=item19d3548be8
for the GT-R. Ad mentions length and height, maybe they will work - will check originals in the morning.
The length of the threaded section is too short?
More likely the inner tie rods are too short or too long. Havent seen variations on outer tie rod length, but I have come across multiple inner tie rod lengths with otherwise identical thread/diameter on the rod.
I think I bought gtst rods for my stagea. They were too short. I eventually cut some threads off a GTR outer tie rod (290mm total length down to 280mm)
Do you have your original tie rods to compare to?
The tie rods they got were too short (overall length). Pretty sure they would have been GTSt ends. They managed to fit the correct lengty inner rods, which was the main reason the car was in in the first place.
Anyway, semi-solved - put the old ones back on for now, ordered a pair from eBay.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
