R/c Traxxas 1/16 Slash 4X4 Truck,velineon Brushless + Hopups, Hitec Servo + 2X Lipo Batteries
Up for sale is a used Traxxas 1/16 SLASH 4x4 VXL Brushless in very good condition, Powered by the Powerfull Vxl 3m Velineon Water proof Brushless System Wheelies on Demand!, Can reach over 80kmh with the right gearing.
Hop ups include Traxxas Rick Huseman Painted Fabtech Body, Hitec Metal gear Servo, Esc has a custom dual deans connector so you can connect 2 x lipos at the same time , 2 x Lipo battery's 7.4v 1500mah Turnigy Nanotech 25- 50 c High discharge rating only used 2 cycles. Because the esc is wired parallel connecting 2 of the lipos you get 3000mah of run time which is about 50 minutes of fun depending how you drive. (you dont need to run both lipos at the same time if you dont want to).
Tyres have allot of tread left, wheels have been sprayed black, gearing is 23 pinon 45 spur, recently changed shock oils to 40wt, Fly sky 2.4ghz radio with failsafe - great range.
Price $320 for the lot and can also include a Lipo balance charger for an extra $20.
Reason forsale is im selling all my 1/16 sale traxxas rc cars.
Pick up from Glenroy - Melbourne (North Western Suburbs or can post Australia wide for an extra $20
call or txt 0422756270
Edited by G4orce
  • 3 weeks later...
  • 4 weeks later...
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
