Hi everyone,
Would like to get a feel of what people are using in terms of oil coolers, sandwich plates in particular.
I'm quite sold on a 19 row for 4 hot laps, running Castrol Edge 10W-60 on approximately 300rwkw and
350rwkw+ when it's tuned for E85. Cooler to be mounted driver side behind indicator. Happy to be
advised otherwise if that is not sufficient.
I have not come across many sandwich plates that include the thermostat, oil temp + press sensor holes
and cooler line fittings all in one.
One that I have found is from MPR:
http://forum.twincam.org.au/topic/3392-oil-filtercooler-thermostatic-sandwich-plate/
Seems to be the go, but just wondering if there are alternatives.
Cheers
Michael
https://www.sau.com.au/forums/topic/430238-oil-coolers/
Mine has the oil sensors and everything fitted to the block! It is the Genuine Greddy sandwich plate with Speedflow fittings, MSCN black braided lines and just a JJ core... Should be more pics and info in my build thread somewhere (Link is in my sig)...
This is not a perfect setup but works fine so far!
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969652
Similar to this?
http://www.rhdjapan.com/trust-greddy-engine-oil-block-adapter-type-e-57mm-51270
That is what Charles recommneded for me off the forums
Though Michael's one also has an inbuilt thermostat which is awesome
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969668
Haha! Yeah I was just on your page 2 seconds ago! Neat setup!
Does it take long for you to get to temp on the street?
I would say thermostat is mandatory for me considering I'll still be driving the car on the street.
My friend with a 19 row with no thermostat and a piece of cardboard in front of the cooler takes quite a while to get to temp still.
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969681
Mine runs a thermostat! It does take a while to get up to temp but it has a pretty good cooling system setup now ;)
I am due to replace my engine/coolant thermostat as the car has been running cold so i assume once that is all done it should all work together nicely!
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969698
The Greddy one DOES have a thermostat?...
SPECIFICATIONS:
Application: Engine Side
Type: E (Standard Oil Cooler, Non-Relocation Type, Internal Thermostat)
Union: AN8, AN10, AN12
Center Bolt: 3/4x16UNF, M20xP1.5
A DIY cooler set up will cost less than or around $400.
$140 for Greddy Sandwich plate
$150-180 for 19 row Mocal cooler (I bought Mocal because its said that every cooler has been tested to hold 180psi before leaving factory)
$10 x 4 -10AN fittings from Torques UK
3m of black nylon braided hoses
The Greddy thermostat opens up fully at 80 degrees and I think slightly open before that. It is also been tried and tested by many and proven to be very good lol
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969742
SPECIFICATIONS:
Yeah sounds like a good combo!
I thought it was 86 degrees or something but that is pushing my memory and my memory is generally useless :P
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969746
From my shitty memory, I thought it's 80 haha, but I know they slowly open up before it gets to 8x degrees.
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969748
Charles saves the day
I can't read haha
Lol you cant read, we cant remember! Must be an SAU thing.....
But yes they do have a thermostat! The guys at Greddy were awesome to deal with too!
If you want to run gauges make sure you order the adapters for them (Where the blanking plugs are in the image on my thread)
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969756
What gauges would you run? Because I already have oil temp on my MFD, then oil pressure on my cluster, is there anything else that's cool and worth installing? haha
Not in the oil block! Sounds like you have it covered.... I just ran the 3 factory location gauges with Oil Temp, Oil Pressure and Water temp!
  • Like 1
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969762
Next project is to protect the back of the core from rocks from the front tyre.... And THEN try work out some ducting to get it some airflow as we ran it nice and high to keep it out of harms way.... I wanted to locate some of the vents that Andrew has in the front of his standard GTT bar but no luck so far! Looks like an aftermarket foglight surround or something but would be good as a small duct for airflow!
https://www.sau.com.au/forums/topic/430238-oil-coolers/#findComment-6969768
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
