The Greddy one DOES have a thermostat?...
SPECIFICATIONS:
Application: Engine Side
Type: E (Standard Oil Cooler, Non-Relocation Type, Internal Thermostat)
Union: AN8, AN10, AN12
Center Bolt: 3/4x16UNF, M20xP1.5
A DIY cooler set up will cost less than or around $400.
$140 for Greddy Sandwich plate
$150-180 for 19 row Mocal cooler (I bought Mocal because its said that every cooler has been tested to hold 180psi before leaving factory)
$10 x 4 -10AN fittings from Torques UK
3m of black nylon braided hoses
The Greddy thermostat opens up fully at 80 degrees and I think slightly open before that. It is also been tried and tested by many and proven to be very good lol
Wow, do you realise how much easier you just made my life!?
Not sure about RB26, but for a RB25, i bought the 3/4x16UNF and seems to be able to run my exisiting oil filter.
:thumbsup: thanks for clarifying
and what's the general consensus on push lock fittings and hoses. some say they pop off and spill oil, kill motors blah blah blah.
i'm less for the blingy braided line and don't mind me some good ol rubber hose.
i would also use worm clamps to secure the ends if that makes any difference.
I suppose that's an alternative..I actually find using the speedflow fittings a little more daunting though cos I can't see how tight the hose actually is on the barb
Guess I'll be more careful during assembly
Cheers
Next project is to protect the back of the core from rocks from the front tyre.... And THEN try work out some ducting to get it some airflow as we ran it nice and high to keep it out of harms way.... I wanted to locate some of the vents that Andrew has in the front of his standard GTT bar but no luck so far! Looks like an aftermarket foglight surround or something but would be good as a small duct for airflow!
Yeah, how you going with that.....? :P
Mine works well.
Sitting on the freeway it's 70 water, 70 oil. Even after a flogging oil only gets up to 80 something.
Highest I have seen is about 105 after a 15 min track session.
Needs better ducting. But it's all tractor related, so I won't go into details.
Another tip. Run the black conduit over the top of braided lines to stop any rubbing on other parts.
If you want to run gauges make sure you order the adapters for them (Where the blanking plugs are in the image on my thread)
This is the problem I am having at the moment. Standard size gauge sensors are wayyyy to small for the GREX plate. I took the sensors (oil temp and oil pressure) to the dude at my local pirtek and he pretty much said that there is no adapters for them. I was like dafuq? Surely someone else out there is using a GREX plate with adapters in it to run to gauges?!
Any info on what thread sizes and adapter types would be awesome!
Why not mount it behind intercooler and in front of radiator? that way the grill between bonnet and front bar can give you airflow, yet protected?
Nah, there isnt much room there once the A/C fan setup goes back in.... I am going to run a Pwr Str cooler too so gotta find a location for it too!
Im workin on it :P
attachicon.gifImageUploadedByTapatalk 21376525124.119479.jpgattachicon.gifImageUploadedByTapatalk 21376525138.152412.jpg
LOL YES!!! The adapters are further along in my build thread.... Page 30 somthing haha
The ones i used were 1/8npt or something like that! They look like the gold plugs with a sensor thread in them!
Greddy have them on the shelf and they are cheap!
Cheers
It has always been recommended to me by the hose suppliers that with the 400 series barb fittings a secondary clamp (such as the cobra clamps that are designed specifically for these types of fittings) is used, on any hose that will see over 40psi or temps over 60 degrees. They are supposed to cope without one, but if there is any movement in the lines, it can lead to them becoming loose.
http://store.greddy.net.au/index.php?option=com_virtuemart&page=shop.browse&category_id=110&Itemid=93&vmcchk=1&Itemid=93
I can't see any AN10 to 1/8NPT adapters on there or am I just blind? They all seem to be not the right size.
Hope I'm just being retarded.
Well i would go with the retarded bit :P
Nah, i havent looked BUT i do have my reciept handy somewhere.... Ill go dig for it now!
Keeping receipts for your car, great for warranty, not so great when you have to look at the dollar figures at the bottom of them :P
Also i found what you were talking about.
http://www.shopgreddy.com/electronics/electroinc-replacements-and-accessories/oil-temp-sensor-adapter-oil-cooler-block-m18.html
Only problem is that's the US site but i'll just email Greddy and they will be able to get me some. Cheers for the tip, i was stunned when the Pirtek dude told me he couldn't get an adapter. Won't be going back there.
Shit, i forgot too look :P
Here is mine, has the part number and all, got it from Greddy Sydney -
Check SpeedFlow as well, they have a new series of adapters like this as well, they don't seem to come up on the website, but their product code is 912-M18-02-BLK for a M18x1.5 and 1/8"NPT adapter.
Lot's of useful info in this thread! Thanks guys :D
Many aftermarket gauge sensors are 1/8PT so it's a little annoying that it doesn't come with the block.
I take it you'll need one for an oil pressure gauge too, which are also commonly 1/8PT for defi gauges and alike?
Yeah actually i got one of these in black for my radiator...
Yep i run one for pressure and temp! Work well so far :)
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
