no...but it does make spark plug changes sooooo much easier :rofl:
hell yeah, depending on the particular intake / car some other stuff may have to be moved around (battery??)to accomodate the repositioned tb
but it would be worth it just for the better accesss to plugs/ignition coils
When the AUD was trading at USD55c and Greddy and Nismo plenums were extremely expensive a cut and shut might have made sense to someone.
Today you can buy a buckchoy front facing plenum for a round of drinks.
hopefully the quality will have improved with time, id be annoyed if i spent hours fitting up a china intake just to have the bastard leak on me
It's not mines but I got the picture online. The one below is my friend car. Rb25. He literally beats his car. Drifting, burning out and he also daily the car. No problems so far. 3rd year it's like that
Did he notice significant or any improvement at all?
Maybe we need a pro and cons list.
pros
less pipe work
easier to change plugs
cons
unknown effect on air distribution
better chance of a defect
then it's just a matter of weighing it up.
  • Like 1
I guess the best way is if someone goes on dyno with normal plenum and then does the C&S job and see difference. Highly doubt there would be any volunteers.
I also add to SUPERBEN's con list that it could lean cylinders out although we have no proof of this thus far
sigh.
Don't worry mate, I agree with your sentiments exactly.
If people want to screw up their cylinder balance that's their prerogative. It is just a big flashing RUN AWAY sign if I see a car like that, I instantly know the owner has taken many other shortcuts.
Mostly I just feel sorry for the car. Nissans deserve better.
but bro, my mate Habib said it would be fully sik and give me 20kw more powah!
how can you argue with THAT.
but bro, a bunch of internet people just told me it wouldn't work with no factual evidence to back up their claims..
how can you argue with that?
reading through some toyota forums and they have the same arguments on there about the old 7m intake and the jz ffp...now it looks to me the JZ just put the throttle body on the front of the plenum...there was no dramatic changes to the runners or anything its all the same shit...but the TB is on the front now....maybe they realized it makes no difference whatsoever where the TB is when the charge supplied is under pressure...Thats what a plenum is for to accumulate and store the intake charge..the cylinders will then suck in what they need, when they need it..maybe it would make a difference on a NA that has to draw the air in itself..but a boosted car has a plenum full of boosted air...there is plenty there for everyone...
now i imagine the internet theorists are now saying but the forced air is getting pushed to the back cylinders more which is causing it to lean out there...but by that theory one would have to assume the stock design is just forcing more air into the middle cylinders in which case the end cylinders would still be leaning out
So while I do agree it looks like balls...I'm not convinced it is a bad idea.....its just an ugly one and we have all been balls deep in an ugly one before..
  • Like 1
I think thats the most plausible response on the topic thus far
The only down fall I see with a cut & shut is the way the air travels. If looking a stock manifold from the side, it makes a flow able loop from TB to head ports. No hard hitting junctions. When I see the cut & shut manifold, I see the air damning in the back before it starts making a loop around. Looks like extra work for the air flow. I think the Greddy version helped with that hiccup while gaining air volume for less restriction. But then again it still rams the back. If you also compare to Honda motors which are insanely mechanical marvels making a 100hp per liter N/A, it has the same style of engineering as a Greddy style manifold from factory. Just my thoughts. It does seem like a lot of work though to gain easier access to the plugs and coils. But I must admit it does look unique. First time I've seen that to be honest. But that is what is so cool about this engineering stuff with motors, it just might work better than a Greddy. It'd be awesome if someone had some dyno tests done between the different styles. Low, mid, and high end lost or gains.
agree with this 100 percent..funny as..maybe its not worth doing..i agree with that....will it lean out cylinders..i highly doubt it, have a funny feeling you
have more problems with tapered plenums in that regard, but i have no factual evidence to back that up
cheers
darren
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
