Well the parking foot brake has been faulty for years (foot pedal will depress but won't release when i pull the lever) now so I don't use it at all. But this is the first time the light has come on. If that's just it I shouldn't worry?
Sounds like the cables have seized up, which I think happens sometimes back when I owned a C34. Could be a problem if the brake pads are pressing on the discs. It's certainly worth jacking it up to see if that's the case. If you were here in NZ, a 6 monthly warrant of fitness check would keep your car off the road if the parking brake failed.
Thanks, will check when i get home. Top up and service in a couple of weeks so all good.
Definitely low brake fluid Nick, had the same issue with mine, topped up and it went off. Just check the level, I can almost guarantee you that it'll be on low. You might be due for some new pads as well.
http://www.skylinesaustralia.com/forums/topic/424151-sticky-parking-brake/#entry6948181
Well after having the pedal seize right up on me, I thought it was definitely going to be a removal job.
To avoid that, I gave the WD40 treatment another go. This time I had to lay down mats, newspaper and towels to stop the WD from getting onto the carpets. Using a bit of PVC tubing attached the can I was able to soak the pedal mechanism from every angle, completely soaking the area until the WD was running off onto the towels. Repeated a few times.
Well f**k me, it worked a treat. It freed the mechanism right up, the pedal now releases fully when you pull the brake release. My only concern is that I did wash off some grease on the pedal, so hopefully I haven't affected any lubrication points, but if I have to add some oil or grease in future its not too much a big deal.
Will report back if I actually ended up ruining the pedal, but so far so good. Beats having a stationary vehicle.
