I'm using an AEM UEGO as well. Thing is, I'm not totally confident it is 100% accurate. I have a feeling it might read a bit rich, otherwise my tune is extremely rich. Frequently seeing ~12.5 on cruise. But I need to ask my tuner to check how accurate it is next time it goes on the dyno.
That said, I'm otherwise happy with the AEM. I've just finished wiring it into my G4 expansion harness which was very straight forward. The Zeitronix kit looks the goods as well though!
Mine seems to be pretty accurate and very responsive!
I use Innovate MTX-L, appears to be a tiny bit laggier than my old Innovate LC-1.
I installed a AEM UEGO on Phil's S15 not long ago and they seem pretty good in terms of response, however his is mounted a little closer to the exhaust housing of the turbo where as mine is mounted pre cat.
so where is the point of difference in all these products?
the sensors will be quite similar yeah? just bosch units or what-not? is the difference in the controller bit? i thought all we want it to do is send an accurate AFR and that's it and let the ECU handle the rest?
if you are aussie there is no reason why you should not use the techedge. you don't even have to buy the display with it which makes it cheaper.
been using them for years, and i own 2 units now. cannot fault them at all. I even had a issue with the long sensor cable and he was nice enough to replace it for me for free when it was not really even covered under warranty and the turn around time for the repair was only 2 days.
all parts and cables are available to purchase seperatly, so you don't have to buy a whole new wideband sensor if you destroy the power cable or the wide band cable.
all he does and all he has ever done is build wideband meters, no one knows as much about wide band as this guy.
cannot beat that shit.
Yep I splashed out on a TE WB3A2 and all manner of cables and adapters a few years back . It has all kinds of logging abilities most of which I'll never use . It's wired into a Vipec plug in nowdays and works really well . The only thing I ever did was drop it in to TE in Canberra to adapt it to their current fastest I think Bosch LSU 4.9 probe . It heats up faster than the one it came with and my tuner requested a new probe when the plug in was fitted and tuned .
If you only want an 02 input for your computer you can buy them cheaper and not pay for features you aren't using . I use the small LCD display so I know what's going on when the lap top isn't online .
I'd buy Tech Edge again , cheers A .
yeah i got the 3A2 as well, had it since 2007 i think... its still going strong. its got the usb interface. its been dropped, wet, left in 55deg + heat for days on end and its still going strong.
I also go the basic 2j2 unit.
if you want a good unit for tuning cars then grab 3a, if you just want one for one car the 2j2 works great.
these things are rock solid, why bother with the seppoes crap ? you dont use AEM computers why use AEM wide bands ? its just silly.
I got this depo gauge...seems all right has Bosch sensor..
Started reading lean, turns out my fuel filter needed replacing...replaced fuel filter now wideband reads error...tried to calibrate it but no response..:unsure:
Pretty sure sensor is still fine , if unit is dead can I just get the techedge so I can link it to my adaptronic?
I seem to misplace a bookmark about wb testing, AEM was at the bottom in terms of how fast it reads and accuracy. A .01 difference compared to LC1 and the other brands that was tested. I had an LC1 first unit was DOE got a new one and it worked peachy.
Im going to try and google n see if I can find the article.
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
