Who's Running A Wideband And What Are You Using?
SS8_Gohan
 Share
I upgraded my firmware to 1.17 and switched the sensor over to 4.9. It lasted about 3 months and died.
Also, innovate says that if you unplug the sensor while the control box is powered it will kill the control box.
They finally emailed me back for a repair and gave me an RMA number.
I've been using an mtxl for 10 months now. No issues so far but by the sounds of it, I should start saving for a replacement. I shall return to this thread for a rant when it happens. Lol
Mafia that's what i thought too. .. I heard wb o2 sensors should be further down. At least for the sensors to not fail quickly. .. I was also thinking to install mine at the turbo dump pipe but i think I should install nearer to the cat.
Ive been running an MTXL for about 18 months and 20k kms. Still running fine as far as I can tell, the gauge is very responsive.
As above, it connects digitally to the adaptronic ECU, and is recommended by adaptronic themselves. That was a simple enough choice for me.
So are all the installations a new bung welded at least 1 metre downstream in the exhaust? Is the sensor tip pointing downwards as much as possible? On the stagea at least it narrowed it down to only 1 location: just before the cat (almost at the flange of the dump pipe) pointing up into the cavity.
There's also the sensor type. The MTXL seems to be upgradable to the LSU 4.9 sensor. Im just running a 4.2 sensor and it works fine for me. Im going by the principle of "if it aint broke don't fix it".
Those are some things to try before writing off the unit. Maybe there is an internal design fault. It does combine sensitive microcontrollers with high current capability, that's always a fun mix.
 Share
