I upgraded my firmware to 1.17 and switched the sensor over to 4.9. It lasted about 3 months and died.
Also, innovate says that if you unplug the sensor while the control box is powered it will kill the control box.
They finally emailed me back for a repair and gave me an RMA number.
Ive been running an MTXL for about 18 months and 20k kms. Still running fine as far as I can tell, the gauge is very responsive.
As above, it connects digitally to the adaptronic ECU, and is recommended by adaptronic themselves. That was a simple enough choice for me.
So are all the installations a new bung welded at least 1 metre downstream in the exhaust? Is the sensor tip pointing downwards as much as possible? On the stagea at least it narrowed it down to only 1 location: just before the cat (almost at the flange of the dump pipe) pointing up into the cavity.
There's also the sensor type. The MTXL seems to be upgradable to the LSU 4.9 sensor. Im just running a 4.2 sensor and it works fine for me. Im going by the principle of "if it aint broke don't fix it".
Those are some things to try before writing off the unit. Maybe there is an internal design fault. It does combine sensitive microcontrollers with high current capability, that's always a fun mix.
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
