UEGO is a little older and uses the LSU4.2 sensor.. hwoever has serial out which is perfect for direct integration into the Adaptronic ECU instead of using the 0-5V analog output which is inaccurate.
if you're using the serial out on the wideband to the adaptronic then don't worry, the ecu will know the sensor is offline.. if you're using 0-5 to out.. and analogue in.. when the wideband fails ecu will dump in fuel and think it's leaning out
  • Like 1
Using an AEM SCG1 boost controller and wideband for 2 years. Has been faultless. Overboost safety and lean condition safety is great.
Good stand alone unit with a 0-5V output for ECU integration. Can't fault the unit.
On 29/06/2016 at 9:05 AM, omnigear said:
happen to share the raspberri display ? I want to replace my non working clock and put a screen there for the wb gauge, but they dont make anything commercial that fits.
https://thenack.com/2015/12/raspberry-pi-car-shield/
The pics are a bit old (have switched to the official 7" touchscreen).
I've been using the Autometer wideband. Was going to use a AEM but went the Autometer as it has self calibrabation on start up.
The AEM doesnt require free air calibration. The sensor has a resistor pack that does the calibration. For 3 years i never touched mine and it was fine
Sorry Innovate SCG1. Silly me.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
