I'm using an AEM UEGO as well. Thing is, I'm not totally confident it is 100% accurate. I have a feeling it might read a bit rich, otherwise my tune is extremely rich. Frequently seeing ~12.5 on cruise. But I need to ask my tuner to check how accurate it is next time it goes on the dyno.
That said, I'm otherwise happy with the AEM. I've just finished wiring it into my G4 expansion harness which was very straight forward. The Zeitronix kit looks the goods as well though!
Mine seems to be pretty accurate and very responsive!
I use Innovate MTX-L, appears to be a tiny bit laggier than my old Innovate LC-1.
I installed a AEM UEGO on Phil's S15 not long ago and they seem pretty good in terms of response, however his is mounted a little closer to the exhaust housing of the turbo where as mine is mounted pre cat.
so where is the point of difference in all these products?
the sensors will be quite similar yeah? just bosch units or what-not? is the difference in the controller bit? i thought all we want it to do is send an accurate AFR and that's it and let the ECU handle the rest?
if you are aussie there is no reason why you should not use the techedge. you don't even have to buy the display with it which makes it cheaper.
been using them for years, and i own 2 units now. cannot fault them at all. I even had a issue with the long sensor cable and he was nice enough to replace it for me for free when it was not really even covered under warranty and the turn around time for the repair was only 2 days.
all parts and cables are available to purchase seperatly, so you don't have to buy a whole new wideband sensor if you destroy the power cable or the wide band cable.
all he does and all he has ever done is build wideband meters, no one knows as much about wide band as this guy.
cannot beat that shit.
Yep I splashed out on a TE WB3A2 and all manner of cables and adapters a few years back . It has all kinds of logging abilities most of which I'll never use . It's wired into a Vipec plug in nowdays and works really well . The only thing I ever did was drop it in to TE in Canberra to adapt it to their current fastest I think Bosch LSU 4.9 probe . It heats up faster than the one it came with and my tuner requested a new probe when the plug in was fitted and tuned .
If you only want an 02 input for your computer you can buy them cheaper and not pay for features you aren't using . I use the small LCD display so I know what's going on when the lap top isn't online .
I'd buy Tech Edge again , cheers A .
yeah i got the 3A2 as well, had it since 2007 i think... its still going strong. its got the usb interface. its been dropped, wet, left in 55deg + heat for days on end and its still going strong.
I also go the basic 2j2 unit.
if you want a good unit for tuning cars then grab 3a, if you just want one for one car the 2j2 works great.
these things are rock solid, why bother with the seppoes crap ? you dont use AEM computers why use AEM wide bands ? its just silly.
I got this depo gauge...seems all right has Bosch sensor..
Started reading lean, turns out my fuel filter needed replacing...replaced fuel filter now wideband reads error...tried to calibrate it but no response..:unsure:
Pretty sure sensor is still fine , if unit is dead can I just get the techedge so I can link it to my adaptronic?
I seem to misplace a bookmark about wb testing, AEM was at the bottom in terms of how fast it reads and accuracy. A .01 difference compared to LC1 and the other brands that was tested. I had an LC1 first unit was DOE got a new one and it worked peachy.
Im going to try and google n see if I can find the article.
    • Hey guys, I’m a veteran detailer with years of hands-on experience. I’ll be sharing quick, effective detailing tips to help you keep your Skyline (or any ride) looking its best. Got a question? Fire away!
    • I guess when I say it's a POS I mean.. the solution and the stuff has the capacity for maybe... 1 spot. You know, as a spot cleaner. What I really *want* is the ability to do an entire car, all upholstery, all carpet, mats, all seats, door card inserts, A pillars, roof liners, etc. In one go. I get lured by all the jank that comes out and think "I'd like to be able to clean to that degree"
    • I've got one (not the car one, the domestic spot cleaner one, which is basically the same jobbie) and have driven it hard for hours and hours at a time. Grimy sofas, 6' floor rugs, etc. I'd blame your specific example rather than the whole category. I haven't used mine in the car, because.... you know, it's my car. So there is no-one else's ball sweat in the driver's seat, there's no kid food/drink spills or hand prints inside because they've never had an opportunity to put them there. You know, basic, standard Skyline rules.
    • I normally run with I think a 10mm, and definitely use the second handle you can add to a drill. They hurt when they bins up!   For the crush tube, once all subframe is clear, I'd try some stilsons and see if I can get it to start to twist.
    • Probably because they couldn't, because the use of the variable resistor to create a "signal" in the ECU is managed by the ECU's circuitry. The only way that VDO could do it would be if they made a "smart" sensor that directly created the 0-5V signal itself. And that takes us back to the beginning. Well, in that case, you could do the crude digital (ie, binary, on or off) input that I mentioned before, to at least put a marker on the trace. If you pressed the button only at a series of known integer temperatures, say every 2°C from the start of your range of interest up to whatever you can manage, and you know what temperature the first press was at, then you'd have the voltage marked for all of those temperatures. And you can have more than one shot at it too. You can set the car up to get the oil hot (bypass oil coolers, mask off the air flow to oil coolers, and/or the radiator, to get the whole engine a bit hotter, then give it a bit of curry to get some measurements up near the top of the range.   On the subject of the formula for the data you provided, I did something different to Matt's approach, and got a slightly different linear formula, being Temp = -22.45*V + 118.32. Just a curve fit from Excel using all the points, instead of just throwing it through 2 points. A little more accurate, but not drastically different. Rsquared is only 0.9955 though, which is good but not great. If you could use higher order polynomials in the thingo, then a quadratic fit gives an excellent Rsquared of 0.9994. Temp = 2.1059*V^2 - 34.13*V + 133.27. The funny thing is, though, that I'd probably trust the linear fit more for extrapolation beyond the provided data. The quadratic might get a bit squirrely. Hang on, I'll use the formulae to extend the plots.... It's really big so you can see all the lines. I might have to say that I think I really still prefer the quadratic fit. It looks like the linear fit overstates the temperature in the middle of the input range, and would pretty solidly understate what the likely shape of the real curve would say at both ends.
