Well when I first got the AEM, BEFORE I had any suspicions about it's accuracy, my tuner actually commented about how accurate it was. Said it read dead on exactly the same as his. I'm only suspicious now because of how rich it reads, but that could well be my tune.
i'm sold, techedge it is
http://wbo2.com/2j/2j9.htm
So all i need is 2J9 + cables + sensor? (17123)
Yup.
it is a good idea to grab a LX1 display to go with it if you can afford it. that way you can be sure the input settings are correct in the software on your ecu because you can compare it with the external display, also if the car leans out when your into it you can see it on the fly.
I got this depo gauge...seems all right has Bosch sensor..
Started reading lean, turns out my fuel filter needed replacing...replaced fuel filter now wideband reads error...tried to calibrate it but no response.. :unsure:
Pretty sure sensor is still fine , if unit is dead can I just get the techedge so I can link it to my adaptronic?
start again and get a new sensor with the TE. peace of mind is a good thing and they are not very expensive anyway.
I am pretty sure depo is a china brand.
Not sure, Says Japan on their site, was about the same price as AEM so figured it was an entry level unit...hopefully I can get it up and running again..its a cool little gauge but can't find the instruction booklet to figure out why the error code...
Good timing for this thread to pop up... I'd just decided to drop some coin on a wide band unit that I'll have wired in permanently, when I noticed this thread.
I had my eye on a Koso unit from the states, but after reading Guilt-Toy's advice I think I'll go for an 2J9 Tech Edge unit with LX1 display.
Edited by Ryno
Crunch the numbers and find the price difference between the 2J and the 3A models, remember the techedge site doesn't quote gst, the initial pain to your wallet will soon pass and it's much cheaper to buy right the first time.
just curious on why people prefer the tech edge over all in one units such as AEM UEGO, Innovate MTX-L, LC-1, PLX?
Is it because it uses the BOSCH LSU 4.9 sensor instead of the LSU 4.2 sensor?
I bought mine mainly on reputation, a few of the tuners I've spoken to use them, and have told me the people who design and build them know their shit and they are built to a standard not a price. As for the all-in-one gauge and driver, I would have liked a gauge but this was only a secondary consideration, accuracy and quality took priority, after all this is a tuning tool not another dial to rice up my dash. Also the driver will accept uego and multiple bosch sensors.
Mike.
Edited by Missileman
^ fair enough, I don't use widebands to rice up my dash either. I've always used all in one units to street tune my car and my friend's cars, one thing I've notice is that there's always a little lag time between the pedal being depressed vs. the readout from the widebands I've used.
I posted the nistune graph in your other thread and you saw how little lag there was when I jumped off the throttle at 60, about 1/3 of second lag, and that was at minimal gas flow. I believe the techedge gauges would read at the same speed/lag as nistune.
bosch 4.9 mounted before the cat
See how we go :)
I've recently just installed a AEM UEGO gauge on my mate's S15 just right before the cat (japanese downpipe already had a pre welded bung). I'm plugging up his Nistune either this weekend, just waiting to see if his missus will let him out for a day haha
ok....reasons im getting an error or code "03" (as it appears on my unit)...have tried to recalibrate but pushing its button does nothing....
bosch sensor has barely 3000km on it...originally had this problem with not getting enough power, but I fixed this when I rewired it...unit is getting 12v or thereabout and it was working fine until I changed a fuel filter, I also drained the tank a few times...none of which should have any effect on the wideband I thought...i did have it running too rich for a while, have fixed that... pulled sensor out and looks clean...
Anyone got any ideas here, I'm stumped ?
  • 5 weeks later...
Have you check if the O2 sensor is heating up?
this, i have a faulty unit and even though the voltage was being sent to the sensor it would not heat up. you can light a cigarette if it works =p
Take the sensor out of the exhaust and feel it. If it gets hot quickly it is working. Careful you don't burn yourself...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
