  • 2 months later...
I have been using the AEM wideband for 6 years now, couldn´t be happier with it. Works great, no calibration needed and all the electronics fit in the 2" gauge :)
$T2eC16Z,!ykE9s7t)2UyBR-QHE0IEw~~60_12.J
I'm running the same unit in my car, and it follows exactly with the Dyno operators setup, gives the same readings, Not sure what he has though.
I personally run a NTK AFX which I bought on recommendation from reading through American forums with input from reputable big name workshops with tons of big hp cars. I was gonna buy something different for the other car but I think I'll just buy another NTK.
  • 2 years later...
I'm going to get a 20L drum, cut the top off, and then collect all the f**ked innovate LM2 hand controllers I have encountered (Including 2 of mine) pour fuel in, BURN ALL OF THE dream boats, and then with the molten plastic and slag, get f**k YOU TO HELL INNOVATE engraved on it, and post it to them.
Innovate can eat the biggest, fattest and longest of dicks.
The units last about 1-2 years. Then they go to shit. They f**k up in a shit way - the AFR reading rubber bands between 10 and 40 AFR and is absolutely f**ked. Powersupply on the car a little shit? No problems, just be an asshole and don't work at all innovate.
The analogue outputs don't even f**king work properly. they have 2 analogue outputs - one works, 0-5v the other doesn't work at all even though they boast the unit has two. False advertising.
Their customer service is ZERO
Their response to emails - ZERO
The quality of their units - ZERO
The parts availability - ZERO
f**k them.
I'm going to buy a techedge unit and never trust innovate again.
For all my CAN BUS needs on the Link G4+, I have been using hte Ecotrons ALM-CAN and ALM-CAN II. I worked with link to get templates made up so you can just load the file and it connects. I have permanently mounted one in my car over a year ago and still going good. I have installed about 5 other units, and 2 dual units without an issue. CAN is just so f**king easy. They are all 4.9 LSU too, and now with the ADV sensor.
Edited by The Mafia
My previous M800 had a controller built in for my 4.9.
Unfortunately the G4+ plug in has none so fitted a KMS eugo CAN a little xii but wtf http://kms.vankronenburg.nl/products/accessories-2/uego-can-controller/
How much was it? Always looking for good prices. And link having support for it is a bonus.
I paid 345 euro 1 1/2 years ago from this outfit. http://www.akracing-shop.de/KMS-Einspritzanlagen/KMS-CAN-Breitbandlambda-Set.html If you hunt around you may find it cheaper.
I looked at the Chinese Ecotrons one first but have been burnt before buying from there so went with this one and no complaints.
Went CAN to avoid voltage signal offsets etc.
I've been having luck with Ecotrons.
I'm with you too - I like CAN because the voltage offsets, bad earths etc give me the shits when they don't work properly.
For sure! nice to know what you are seeing is correct.
can recommend the 14 point 7.com spartan controllers using the LSU4.9 sensor. they're 75 USD for the controller.
basic, but have a 0-5v output and are cheap with automotive grade gear. haven't had an issue with mine. haven't used the sigma 2.1 controller but has a display and multiple inputs if you're into that kinda thing.
http://www.14point7.com/products/spartan-lambda-controller-2
Edited by burn4005
DO NOT USE THE INNOVATE MTX-L.
They cook sensors, then after they cook sensors the gauge will cook itself LOL
Also there are two versions of the LM2, the older is a piece of shit because it uses the old LSU 4.2 sensor not the newer LSU 4.9 found in the latest version.
I have the old croc of shit version which somehow just shows W27 most days and some days work lol.
The main reason I use Innovate is because of their serial out, which directly integrates with Adaptronic also they're the only ones on the market with a handheld wideband which I use to tune other people's cars (not so much these days, as I just tell people to install widebands before seeing me).
However, I am game enough to try the new LM2 that uses the LSU4.9 sensor.. hopefully no more wacky readings and W27 errors (also wtf is W27? it's not even in the manual)
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
    • Far out, that thing looks like some loose fun!  Nothing beats the rawness of a filthy old Nissan with zero aids to keep the wheels pointing in the right direction like modern "fast" cars!
    • If there is no ridge at the inner edge of the battery tray (ie the battery tray is flat until it rolls off the edge into the open space of the bay), then no, it won't matter if it overhangs. If the battery would be propped up by any ridge, then that wouldn't be ideal. The bottom of the battery case would not be sharing the load. It would be concentrated on one end edge and a line across the bottom where it contacts the ridge. And possibly it wouldn't fit under the locking clamp either. I only upsized my battery to the max because: I sometime have to leave my car undriven for weeks at a time while I am away for work. On the previous battery (replaced a couple of months ago) I had to leave it undriven for months at a time!! I sometimes abuse the battery by running the stereo up loud for many hours while I wash and polish it. This is how I realised that the previous battery was on its last legs, because it got to the point where it was too weak to start after a couple of such. It was 7 years old though, so, fair play. Supercheap had a good special so the X was only ~$250 instead of ~$320, which seemed sufficiently less painful. I had already been using NS70 for the previous 2 batteries for most of the same reasons as above. The X is just the final boss level. I was contemplating going LiFePO4. But it's like $900 to do that properly, and while you save >10 kg of weight, you can likely only expect a couple of years longer life. So meh. Maybe when the price comes down further. Although, in ~7 years when I have to replace this one, I might not be allowed to drive such an anti-social vehicle anyway.
    • If I get a larger battery and it hangs off the edge of the frame rail, would this be an issue? With FMIC a lot of people downgrade their battery size due to less room for shit, was wondering if it would affect anything but it would still be tight via the clamp.
