I upgraded my firmware to 1.17 and switched the sensor over to 4.9. It lasted about 3 months and died.
Also, innovate says that if you unplug the sensor while the control box is powered it will kill the control box.
They finally emailed me back for a repair and gave me an RMA number.
Ive been running an MTXL for about 18 months and 20k kms. Still running fine as far as I can tell, the gauge is very responsive.
As above, it connects digitally to the adaptronic ECU, and is recommended by adaptronic themselves. That was a simple enough choice for me.
So are all the installations a new bung welded at least 1 metre downstream in the exhaust? Is the sensor tip pointing downwards as much as possible? On the stagea at least it narrowed it down to only 1 location: just before the cat (almost at the flange of the dump pipe) pointing up into the cavity.
There's also the sensor type. The MTXL seems to be upgradable to the LSU 4.9 sensor. Im just running a 4.2 sensor and it works fine for me. Im going by the principle of "if it aint broke don't fix it".
Those are some things to try before writing off the unit. Maybe there is an internal design fault. It does combine sensitive microcontrollers with high current capability, that's always a fun mix.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
