All parts from a 1994 Series 1 R33 gtst 4 door I wrecked, cheap cheap!!
Many parts are pick up only unless stated otherwise so read the description carefully.
Sedan boot lid $20. Pick up only.
Rear hubs $20 each (includes uprights). Pick up only.
Front and rear sway bars $20 each. Pick up only.
Rear cradle (bare cradle) $20 each Pick up only.
Non abs brake master and booster $20 each. Can post.
Door cards- no switches included $20 each. Pick up only
Very good condition except one small blemish as shown in photo.
Rear 4 door window switches $20 each (or $40 for all three, driver's switch sold). Can post.
A pillar trims $20 pair. Pick up only.
Doors $20 each. Pick up only.
Rear bar, suit respray $20. Pick up only.
Door lock kit - doors, ignition, boot with key $50. Can post.
Steering rack $20. Pick up only.
Indicator and wiper stalks $10 each. Can post.
Steering column $20. Pick up only.
Kick panels $10 each. Can post.
Dash plastic surround (pick up only) $20
Dash pad $20 pick up only
Sun visors $10 each. Can post.
Front guard mudflaps $10 pair. Can post.
Sold/unavailable:
Motor and gearbox, headlights, airbox, clutch master, bonnet, passenger guard, under stereo pocket, engine fan, speedo cluster, lower control arms, factory stereo, centre console, stock suspension, castor rods, cat temp sensor, inner guard liners, fog lights, climate control, shifter surround, front bar and grille, AFM, ECU, drivers window switch, side mirrors, stock rims, diff, rear brakes, radiator, interior wiring loom, steering column plastics, handbrake, stock intercooler and piping, rear vision mirror, interior lights, front hubs.
How much for the plastic steering column surround thingy, pending it has no holes or blemishes? Posted to 2444 Port Macquarie?
Let me know :)
pm sent :)
is the front fender the same as for a coupe or are they different? sorry if noob question.
pretty sure they are the same
much chance you'd have a stock or a not too loud exhaust catback for a r33 sedan? also if anyone knows if the front end (guards, front bar, bonnet headlights) are the same between sedan and coupe??
nah exhaust sold already, not 100% sure on the front end parts but I only have the driver's guard anyway.
Wouldn't happen to have a speedo drive for RB25 gearbox mate?
i may have one on a stag front cut i have, need to check for ya to make sure it's in good nick
pm me if you want it and i'll check it out
  • Like 1
Hey Mate you dont have the space saver spare wheel by any chance?
Also interested in the radiator support/ boot latch with the horns attached
nah no spacesaver, bonnet latch/rad support is still available
pm me for bank details
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
