So i guess its time to write a build thread.
I bought my R32 GTST a few years ago as an alternative to riding bikes. This is the setup i had for about 10 years before the Skyline.
KTM 360 exc 2 stroke Mitsubishi triton ute
Then I sold the bike and bought the 32
It was rough as guts, overpriced, and i didnt know anything about Skylines.
So i bought it. Oops, oh well time to fix it up.
Ive always been into machines and technology, dad was an engineer, and its in the blood.
But the last time i was into cars was nearly 20 years ago, so this fuel injection and turbo stuff was all new to me.
It ran like crap so i took it to a local backyard mechanic who got it going ok.
it had dodgy intercooler pipes, broken headlight mounts, a few dings and dents, 5 stud hubs, manual conversion, rb25 turbo, dodgy suspension bushes, pedders suspension, and a half-assed 3"catback exhaust.
There was nothing holding up the front bar but a few cable ties, and no front reo. So i chopped up some scrap alloy and had a guy weld it. This was my intercooler and front bar support. (This is a later pic with the new intercooler and an oil cooler)
I knew there were places in Sydney to buy stuff, so i drove the ute up there and got a lockbar, headlights, and intercooler piping kit.
The power steering was fked so i took it to pedders, oops, oh well at least it doesent leak as much as it used to.
Luckily I was told about SAU when I was at a local workshop that specializes in Skylines, and started learning. Now i was using the internet for more than porn and games, i realized i could buy stuff and get it delivered (doh!) no more trips to sydney to buy parts.
I needed a better place to work on it than under a carport, so i built a shed. Diy of course.
Anyway, ill cut a long story short and just list all the mods ive done, and learning as i go, some of the mods have changed. Some are in the Diy/Faq thread, and some are in the fabrication thread.
And some of the dodgy sht i have found from previous moron owners of this car is incredible.
big fmic
new kingpin bearings (what a drama! see Diy/faq thread)
rb 25 turbo, There when i bought it
3" exh w bell dump, after a jjr stainles split saga/disaster
one piece tailshaft, made by Diff Dr
podfilter & cold air box
strut braces front and rear
Neomax adjustable coilovers, early mod, maybe bad choice.
adj upper arms front and rear
DW tracton rods
Hardrace radius rods, DW ones stuffed after 6 months.
DW hicas eliminator
solid cradle bushes
solid steering bush
oil catch can
Ebay radiator
thermo fans
Autometer oil, water, fuel/air, boost guages
post-89755-0-71692100-1376557523_thumb.jpgpost-89755-0-99930700-1376557560_thumb.jpgpost-89755-0-20284900-1376557585_thumb.jpg
voltmeter
volt stabilizer
yellow jacket coilpacks
stereo, amp and speakers
made a new parcel shelf
approved child seat strap mount
rear view camera
sports steering wheel
immobiliser
engine damper
Cheap carbon wrap
post-89755-0-85733300-1376557622_thumb.jpgpost-89755-0-68498100-1376557693_thumb.jpgpost-89755-0-21013000-1376557711_thumb.jpg
Exedy heavy duty clutch
battery in boot
oil cooler and filter relocation w thermostat
removed aircon (never could get it going right, and it overheats the engine)
post-89755-0-33525300-1376557821_thumb.jpgpost-89755-0-94782300-1376557887_thumb.jpgpost-89755-0-82851200-1376558029_thumb.jpgpost-89755-0-69293400-1376557946_thumb.jpg
Nismo shift knob
electric heater (for demisting)
GTR front bar w n1 vents
Nistune ecu
adjustable cam gears
post-89755-0-34452700-1376563422_thumb.jpgpost-89755-0-51711600-1376563444_thumb.jpgpost-89755-0-58129300-1376563546_thumb.jpg
new timing belt
new water pump
rear wiper delete
Deatchwerks fuel pump
Deatchwerks 650cc injectors
Bosch z32 afm
Hel braided brake lines
tune at Autotech
Nismo engine mounts
fire extinguisher
harness and mounts
sparco seat for trackdays
new front reo (now i have a welder)
tow strap
Theres still a few unfinished or dodgy bits that need attention or just tidying up.
The ute and bike funded part of that list of stuff, and DIY of course, keeps it cheaper.
The things ive had to pay to get done were kept to a minimum: the initial tune/fix up, power steering, suspension arms and stuff fitted and adjusted, a flywheel machine, some bearing pressing, and the fitting and tune of the Nistune ecu.
I bought some 17" x 9" +35 Rays Volk GTC wheels for a steal, $600!
Now i have to flare the guards to fit them, i dont knpw what tyres yet, ill see how i go with the guard flaring tool i made.
Im getting into hillclimbing now, and want to do some trackdays at Wakefield.
So the plans for future mods go on.
And i must do a paintjob one day.
https://www.sau.com.au/forums/topic/430316-diy-miks-r32-gtst/
About $780 for the seat. $90 for Sabelt brackets.
A bit of a pain to fit as its hard to reach some of the bolts.
It depends a bit on your seating position, im fairly tall, over 6 foot 3, and cant fit a helmet on unless the seat is on the floor.
If your under 6foot tall, or if you can fit a helmet on in the normal seat, there is a neat solution.
I bought these before i realized i wouldnt fit. It bolts to the original seat mounts.
From the US so there was a mixup with which side i wanted. Ended up with both.
Im going to chop one up and re-do it, so it works for me.
The other is for sale. $140
  • Like 1
  • 3 weeks later...
Fitted a cooling panel, which showed how my lights are out of line.
Fixed it up so it fits well
post-89755-0-89770900-1378270935_thumb.jpgpost-89755-0-78525800-1378270950_thumb.jpgpost-89755-0-22421500-1378270966_thumb.jpg
Made an air sucker to keep the cabin air clean, taped up all holes and gaps from cabin to boot.
And the vent in the right rear guard was stuffed, so i put one there too. They are plumbing aav's.
post-89755-0-58974900-1378271006_thumb.jpgpost-89755-0-74101300-1378271027_thumb.jpgpost-89755-0-48054100-1378271043_thumb.jpg
Bought a proper guard roller, to fit wider tyres. And lipped the guards a bit for starters.
I want to go 255 on the back, thats a 235, im going to use them on the front. i put it there to see how much more i can go.
post-89755-0-52339900-1378271065_thumb.jpgpost-89755-0-33082100-1378271115_thumb.jpgpost-89755-0-00682000-1378271139_thumb.jpg
Replaced the left radius rod bracket with a straight one. This is the old one, bent.
Hillclimb soon, getting the front brakes machined tomorrow, as there is a slight pulse in the front left.
Thats why the radius rod bracket got replaced, the bolt hole was slightly enlarged and allowed the radius rod to move.
Thanks man :D
Totally heaps better.
The old vlsd was flogged out and noisy, was pretty much an open diff as it liked to spin one side.
The Kaaz is really solid and i get a bit of clunk and shudder when turning sharply, like in a carpark.
But its getting better and theres no tyre chirping.
The wheels are on, ready for sunday hillclimbs:
  • 3 weeks later...
Thanks guys,
Rob gave me an alloy induction pipe, it needed to be a little shorter, so i got 50mm chopped out of it and welded back together.
Got the dremel and cleaned up the inside, messy welds and a bit of pipe were in there.
Should have got some photos of the install but anyway.... got a perfect bit of hose for the bov return, from supercheaps radiator hose selection, you can browse as there all on the shelf.
The cold airbox had to be trimmed back, and the washer bottle is gone, so now the filter can fit in there.
Got a universal washer bottle but i still need to mount it, kind of undecided where its going.
Hey Mick, Do you still run your factory seat belt at all with that seat? If you do, how is the buckle mounted?
Yes, ive got it mounted on the rear left seat mount, its a tight fit next to the seat but it works.
Best Build in Australia, keep up the good work Mik :yes:
Thanks man, i put in a lot of effort, but its still a backyard, diy, with hand tools.
I cant wait to do a paint job, then it will look the buisness!
  • 1 month later...
Doing a window net so i can do trackdays with the window open.
And a lower bumper bar to protect the front bar from speedbumps and driveways.
Not finished yet.
post-89755-0-91250100-1386584055_thumb.jpg post-89755-0-04041100-1386584165_thumb.jpg
Exhaust has been re-welded, and fits better.
    • Yep that makes sense, thanks! I guess flogging these turbos in winter is more preferrable lol.
    • Bahahaha, bloody hell Greg. You've got bent and broken things, but instead, you're replacing perfectly good items. This story keeps getting more gregged!   Also, I'd 100% replace that reo if I were in your shoes, unless you panel beater is REALLY good. Even if you put another GTT one on there. Just because you've done so much nice body work lately, I'd say repair the body work fully  If it were more drift car spec, I'd be all "Hit it with a hammer and send it!"
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
