This^^^ :thumbsup:
Patience has been the key thru this whole process Mik, don't lose it now. ;)
Edit* from seeing it in person the other day, it's gonna be Fantastic and well worth the wait / effort.
Its ok guys im just taking some pics i wont damage anything.
Its just that they wont look as impressive as when its all buffed and back together.
But hey, its a build thread and i like to show what its like throughout the process.
Wheres the sun gone... ill wait for direct sun to get the metallic and pearls showing
Edited by D.I.Y. Mik
Yes, its a good idea, acrylic is very soft. :thumbsup:
I wonder if they make clear vinyl wrap........ Might get the good stuff done by a pro if i can.
A few small bits shouldnt cost much to get done.
Im thinking the front and back faces of the skirts, and the front face of the rear pods.
Maybe the black lip on the front bar too.
Mik that is amazing! Can't wait to see it all back together!!
Oh man! That truly does look awesome! Man I love the green with the black lip
Thanks guys! I cant wait to get it all polished and back together.
3-4 weeks at least though oh well, plenty to do in the meantime.
New sway bar bushes and links fitted all round.
Its been 3 weeks tomorrow since i painted it.
Might start wet rubbing with 1200 soon.
Looks good with the gold wheels...... :D
Moved it out of the garage to turn it around , and the brake air deflectors are scraping on the inside of the wheels.
Ill have to trim them up a bit, easy, its alloy, and i have good snips.
Rubbing back the orange peel:
Its going to take a while to do properly and not rub through the clear.
Fairly happy with the few defects, as its showing up the smallest scratches and bits of sht now.
Car body is 2/3 finished, plastics next. Then 3 buffing compunds, a sealer, waxes, re-assemble and a full detail.
Yes, still a lot to do, but it feels good to be near the end.
Random Access Memories will no doubt keep playing over and over, but this car is my "game of love" so im "doing it right".
:whistling:
I cant wait either.
I think its going to look awesome, i imagine it gleaming in the sun like an emerald set in gold. :happy:
Body is rubbed back, about 1/3 done with the plastics.
I have trimmed the brake air deflecors, i think it scraped off a balance weight from the left wheel, will have to re balance it.
Got some good cutting compound from the paintshop where i got the paint and everything, they have been very helpful.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
