First block sanding done and the sludge washed off, now for a bit of filler in the lows and prime again.
Some things i never saw before block sanding, like minute highs from factory spot welds.
The crease on the drivers door is dented and will be quite tricky to make it right, its gotta be dead straight or it will stand out.
There are very long ripples on top of the left front guard, its like two lows over the whole length, so they end up being flat spots on what should be a gentle curve.
How the fk can i fix that? Even a very long block follows the lows.Guesswork sculpting with bog? Ill have a go at least.
Some bits are quite difficult, but thats half the fun i guess. Its just work if theres no challenge. Like sanding the roof, its a bit boring cos you dont have to think much about it.
Sanding the doors requires correct technique and attention, the learning of new skills is pleasurable, its hardwired into your brain as part of our survival skills.
Filling and sanding:
post-89755-0-09902300-1394765509_thumb.jpg post-89755-0-15253500-1394765531_thumb.jpg post-89755-0-73959600-1394765559_thumb.jpg
Had to grind out the bonnet in those spots as there was some old black paint making the primer split and peel.
Couldnt be stuffed fiddling around for hours on the "Skyline" and the grooves on the brake light surrounds. Dont need stupid little detail sht like that. Fiddly bits dont look good, look at a new Holden. :yucky:
Trying to get the rear to match the bar:
post-89755-0-03740200-1394765582_thumb.jpg post-89755-0-80422800-1394765688_thumb.jpg post-89755-0-55145700-1394765715_thumb.jpg
post-89755-0-34970200-1394765731_thumb.jpg post-89755-0-74765100-1394765749_thumb.jpg
Makin a mess: post-89755-0-08911100-1394765766_thumb.jpg
So theres the start of trying to get it straight and smooth, a lot more work to go.
Oh, and i got a new spraygun, dads isnt working too well. Might give it a service now i have instructions.
Another thing id like to point out is that im not much good at panelbeating, its quite a skill, those guys dont get paid enough for what they do.
So im just using heaps of body filler, that rear guard should really be cut off and replaced, after the whole car has been straightened on the chassis aligner.
Edited by D.I.Y. Mik
Colour and clear?
Well it depends on how well i smoothed it all out, hopefully most of it will block back nice, and ill only have to work on a couple of spots.
The plan is only to re spray those spots where i have to, then black in the doors and under the boot.
All the plastics are good and will only need a rub, trackday bonnet may go black to save time, and trackday guards will be used to experiment with the colour, pearl and clear.
When its perfect, ill do a prime/seal coat, rub that with 600, then 800, dust it off, then the colour, then pearl then clear. Wait 6-7 days to cure (actually will do more mods and maintenance during this time), final rub with 1200, and buff.
Then put it all back together.
Its taking a bit of work because my car is so bent. A straight car is waaay easier. If you had no issues with different paints and repairs, you could just scuff it up and spray.
Mine had issues with the paint, so it had to be stripped back to metal. Just paint stripping is a lot of work. Then i saw all the repairs, but stripper fks bog so i had to re-do all the old repairs too.
Looking for a dark green, a little darker than Holden poison ivy.
I will try a bit of gold ghost pearl and see if i can do it without stripes. Spraying tricoats (colour, pearl, clear) is tricky.
I am a member at my local club:
http://www.sdmahillclimb.com/Start.html
I have only raced there, and a couple of laps at Wakefield once.
Got some more paint today, have to wait till thursday for weather to be good for spraying.
4l, plenty of primer to sand into dust. Gotta learn when to stop.
I will have to look at attending some of the Canberra hill climbs, my girlfriend lives there for uni at the moment so would be a good excuse to be over there :P
  • Like 1
A coulple more coats of primer on everything today, and a guide coat.
3l of primer used today... with all the bits and pieces it uses a bit of paint.
Next, sand again, and fill the scratches and tiny imperfections.
The guard, door and bonnet will need a few skims, sands and guides. Its all pretty good except for those 3 areas of damage.
Those areas can be re-sprayed in guide coat on their own.
Then a final thinned out coat of primer, nice and smooth.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
