Only a guard and door to go.... oh, and plastics.
Good thing about the plastics, they wont have dents, only scratches and chips, which can be filled with skim putty.
Should be able to get it all with skim putty now. So touch ups over the putty and a nice thin prime/seal coat on everything. Hit that with 800 wet and its ready for colour.
And yeah, some details on the rear guard need to be sanded too.
post-89755-0-06161700-1395980653_thumb.jpg post-89755-0-89428500-1395980679_thumb.jpg post-89755-0-94099900-1395980665_thumb.jpg
I think ive used about 7 litres of primer so far, thats why its filling all the little imperfections and its coming up so smooth.
There are some interesting things you see when blocksanding, like the slight high spots that show, from where the spot welds are underneath. And the edges of some parts have a slight high lip, from the pressing of the steel when they made the panels.
However... there is a slight low (from factory, its the way the guard was pressed) over the rear wheel arches, extending up past the crease, id like to fill it so the back is totally straight like no other skyline. But its very hard to see and would be very hard to fill perfectly.
Ill have to think about that one.
Putting some fine putty in the scratches and tiny lows.
post-89755-0-67906200-1396153218_thumb.jpg post-89755-0-51960700-1396153267_thumb.jpg post-89755-0-51237400-1396153289_thumb.jpg
Bonnet, door, and that rear guard look bad but actually only need a skim to fill the holes, edges and other small lows.
The shape of the crease on the door is not good, from a profile view. It needs some fixing. Tricky stuff ill have to work out a way. Maybe using tape or something.... :glare:
And the rear guard........ thats our little secret, dont tell anyone how much bog is there. ;)
post-89755-0-71668200-1396153306_thumb.jpg post-89755-0-06771900-1396153321_thumb.jpg post-89755-0-33778100-1396153337_thumb.jpg
Getting there, slowly but surely.
  • Like 1
Havant had much time to do anything lately.
Back into it yesterday, got the sanding of all the little bits and skimming scratches and chips done.
Got a plan for the door (metal strip guides), its going ok by the looks of it.
Bodys all skimmed and sanded, ready for next coat. Except for the 3 major damage areas, which will get several coats of putty and guide before there ready.
Will cheat and just use a whole dropsheet with 3 holes cut out and taped up where im working.
Then i have a decision to make:
- Lots of primer and block sand again with 800, then primer/sealer and rub with 800. This will be a better finish.
- Or primer/sealer and rub with 800 then colour. This will have some defects, but save time. (about 20 hrs)
How many and how bad the defects are is the gamble.
No, you mean the shortcut method?
I need an even coloured base for the colour, so no rub throughs to other coats.
That means a coat of primer/sealer (thinned out at least 50/50) with the roughness rubbed off with 800 or finer.
To fill the minor imperfections i need a thick layer of primer/filler (not thinned out much) and sand it flat again.
Heres a list of what i need to do to finish. if i can do one thing a day ill make it to Shannons open day.
Finish skimming and sanding plastics, then tape off the 3 damage areas on the car.
Finish 3 damage areas (skim, sand, prime, sand, skim, sand, prime, sand, etc untill perfect)
Prime plastics, and guide coat
Clean and mask car
Prime car and guide coat
Block everything in 800 ( 12-18 hrs ) :/
Fix any remaining imperfecions
Clean everything, mask car
Spray prime/sealer
Rub with 800-1000
Clean and mask
Spray colour
Rub with 1000
Clean and mask
Spray pearl and clear
Wait a week or more to cure and harden
Rub with 2000 and buff
Detail window trims, wheels etc.
Hmm...... thinking about how the car is blocked very well. No guide coat or anything.
I really should just prime/seal and then colour.
I have spent a lot of time getting it real nice, im sure its good enough.
I have made a lot of primer into wetsanding sludge on the floor, enough.
New list:
Finish skimming and sanding plastics (done), then tape off the 3 damage areas on the car.
Clean and mask car
Spray prime/sealer
Rub with 800-1000
Clean and mask
Spray colour
Rub with 1000
Clean and mask
- Assemble car (forgot about this one!)
Ps: The plastics were not straight as i thought they would be. There was some warpage in spots and they arent perfectly flat anyway.
They required some finessing to get them nice.
Yes, wet sanding is good. Dont need a mask, paper doesnt clog up and it leaves a nice finish.
All my sanding finer than 180 is wet. I only dry sand to grind back bog and old paint etc.
Primed and guide coat on the 3 damage areas today.
post-89755-0-36580500-1397613996_thumb.jpg post-89755-0-36715800-1397614013_thumb.jpg
Ill let it dry and block it back tonight.
Its time to start the final coats.
Its not perfect, and i hope most people wont see the defects.
Painters and such will notice the flaws, and it would be nice to impress them too, but its my first time and i think its good enough.
So im going incognito until its done and buffed. Then ill take some pics.
This is whats left to do:
Spray prime/sealer
Rub with 800-1000
Clean
Spray colour
Rub with 1000
Clean and mask
Assemble car
  • 5 weeks later...
Nearly one week curing, i pushed my fingernail into the paint thats under the bodykit.
Its still very soft, i will have to wait at least another three weeks or more for a good cure.
Maybe ill start on some other things, as long as i can do them without touching the paint.
Edited by D.I.Y. Mik
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
