You're looking for polished. Not chrome. Most are polished... iv never seen a "chromed" cooler setup. Who would waste their cash chroming cooler pipes?
you'll be surprised, I've had 2 kits just flake off with chrome :)
  • Replies 49
Personally i'd steer clear of china made intercoolers though some have mentioned that their quality control has improved vastly...
the china made ones that i have seen in person...pipings are either porous, bad fitment issues, uneven thickness or have tons of burr that would cut ur hand
the top end greddy kits are beautiful and relatively cheaper, HKS ones are also worth mentioning and Blitz.
Intercoolers while seemingly simple do have some research/tech in them. for example, u want maximum cooling which requires excellent contact of the incoming air with the cooling fins yet u dont want a huge pressure drop. So the tech comes in how efficient is the material used for the fins to absorb convectional heat from the turbo-ed air, then it has to conduct the heat to its outer surface and lose the heat to the cool air passing over it via convection. Some companies manage the restrictive portion by having a special fin layout/design.
hope this helps :)
I have installed plenty of china coolers, some are good, some shit. It is very hard to tell from the picture obviously.
I direct the M35 Stagea guys to HDI, they do some great products, but I think the Skyline kits go under the battery tray. :/
hope this helps :)
Ye man it does. Might get a mate to help me out when looking for intercoolers because so many things could go wrong with second hand and I'm on a budget, so got to be careful and ensure that the FMIC I get lasts.
I have used the kkr black series for an r34 gtt. Running 10psi. Used as a daily
Pros:
400$ for full kit
Black
Fits with minor cutting
Have had it for 20,000km. With no problems.
Fairly light
Cons:
Piping thickness is slightly thin
Cooler core is not as solid as blitz etc
Fins are not as solid as Japanese brands.
May have to trim thermo fan
Conclusion:
Good bang for buck upgrade for a reliable daily. Would recommend other Jap for a weekend or track car
I am happy with the purchase.
Try having a look at the GK TECH kits. Haven't heard anything bad about them. The distributor is a Melbournian and is a good bloke to deal with. Well priced and are most likely a copy of a high priced jap brand. Cant really go wrong there.
That $50 was just for a universal intercooler no piping, commented to highlight that the cheapies work fine usually. You won't usually see a power difference at low boost and power, yes they are usually more effective than stock but it's your car, if you can afford top end stuff and that's what you want then you should get it. It has been proven by many that the cheaper kits, hdi and cooling pro as mentioned, do the job. Regarding piping. You can always shop around. I had quotes from $450-$1000. I luckily found an exhaust shop run by 2 older blokes who made my piping from scratch for $290 and they spent all day on it. Total cost was $340.
Edited by FordyR31
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
