  • Replies 49
I had a china cooler that averaged 38deg intake temps. Then I got a precision turbo intercooler that averages 8deg intake temps
The china cooler would increase by 20deg in a 20 second pull
I don't get how that is possible, it defies physics :wacko:
I don't do physics I can just tell you what the gauge tells me. I assume the cooling ability of the quality cooler is far better than the eBay one
It's not possible to create intake air on the inside of an intercooler that is even as cold as the ambient air cooling the intercooler.
Anybody who claims to have seen it is needs to check their temperature measuring instrument.
Edited by GTSBoy
Ye man it does. Might get a mate to help me out when looking for intercoolers because so many things could go wrong with second hand and I'm on a budget, so got to be careful and ensure that the FMIC I get lasts.
is the intercooler upgrade urgent? if not, maybe u can hold back abit and save up more for a better one?
most quality stuff dont come cheap... :(
*hands keys over reluctantly* so bluddy hard to choose the correct intercooler :(
LOL. It is.....so many brands
That $50 was just for a universal intercooler no piping, commented to highlight that the cheapies work fine usually. You won't usually see a power difference at low boost and power, yes they are usually more effective than stock but it's your car, if you can afford top end stuff and that's what you want then you should get it. It has been proven by many that the cheaper kits, hdi and cooling pro as mentioned, do the job. Regarding piping. You can always shop around. I had quotes from $450-$1000. I luckily found an exhaust shop run by 2 older blokes who made my piping from scratch for $290 and they spent all day on it. Total cost was $340.
You got a point there. I'll see how I go, because the worst thing I can do is buy an intercooler and then later down the track have to upgrade because its not sufficient. Did that with my first car and wasted tons of $$$
PHYSICS!!!!!! :woot:
Very true indeed. No its not, so might as well save. Just have other things to save for as well.
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
