Swap - Haltech Platinum Pro Plug In For Platinum Sports 2000
Hey all,
Before I buy an expansion box.. Is there anyone interested in swapping a Haltech Platinum pro for R33/R32 GTST/GTR for thier Platinum Sports 2000?
Plug in pro will come with:
Aux Harness
3 Bar external Map sensor
Cable
CD
base map for R33 GTR loaded
Pm me
Cheers,
    • Holy hell! That is absolutely stunning! Great work!!!
